are there ABS brackets on my non ABS equip. GTS???
95snoozer
2,572
RCR
I was wondering if the brackets and junk is still there even though I dont have ABS. cause I knwo alot of other stuff still gets put on even though I have no options, its still there in the car. I.E. harnesses and such..
If they are there, I would liek to remove the dead weight :D
wha to look for?
The ABS sensor is behind the rear wheel. You can follow the wire from under the back seat, down the LCA to the bracket that holds the brake caliper on, if you are equiped with the system. I don't think you would lose any weight by taking it off if you do have it. Hope this helps.
Paul
