Are these Drilled Disc Rotors Any Good?
For daily driving, they should last a while. Common problems are hairline cracks starting along the holes. I would not recommend them for track use.
I jsut got back from my first drive with a set of powerstop drilled rotors. They work great.
fasttback said:
consensus is...just for looks. That's all I needed to know. Thanks for the input.
Pretty much. People simply cashing in on a fad. Even Cheverolet has yanked them off the Z06 due to the crossdrilled holes creating cracks and rotor failures. If the manufacturers can't make them safe what makes you think Jim Bob in the back of his garage is going to make you a better set?
