I just bought a 93 5.0 5-speed coupe:
My car idles great with either the TPS unplugged or the IAC motor unplugged. If both are plugged in together the idle jumps to 3,000 rpms, but will drop back down if you push the clutch to the floor.
I checked TPS voltage and it's at .97, but it only goes to 2.61 at WOT and swapping to a new TPS doesn't fix it either.
Also, I can't scan the codes with my Snap-On diagnostic scanner. The scanner works fine on my other Mustangs.
I'm thinking the ECM is fried or some computer wiring is bad. The car runs fine with the TPS completely unplugged and it even drives good with it unhooked. The car does feel weak compared to others i've had though.
What do you think?
What do you think?
