YEAHLOH95
i agree twins will be the way to go with a custom kit fromj whom ever can make it , but like it was asid b4 do alot of research first
94gts said:i say watch this video
i think this guy has his stuff together
http://www.centralfloridaturbo.com/videos/williesmustang.wmv
fox racer said:I dunno, im impreesed but a little disappointed. thats an incredible 1000 hp, even the 700+ is amazing. but all he could do is crack 10s, barely? was he running lower boost at the track? or can he not get the car to launch. im confused, b/c thats low 10s power.
Don't tell me i have a lot to learn, that may be true but i don't need you telling me that. First thing, i made the same mistake as some of the other peope in missing that he was only running 13lbs. Sencond I have been to the track a total of 4 times in the last year and half... And only once with my last setup and a decent set of tires. I ran a 10.96 @ 128 before i was asked to either calm down or put a cage in... Thats a car that dynoed 489 rwhp and about the same torque. No extended rpms just 12lbs of boost. So when i see somebody that has over a hundred plus more horse and a lot more torque I think its kinda sad and discipointing when they beat me by less then a tenth and the mph seemed a little low... If i had a good auto tranny like im planning on getting i could have done faster with less ... maybe not 300rwhp less but at least 150rwhp.. Dont' get me wrong i think the car is bad ass but im just kinda discipointed. And my last point... I have seen people run in the 9's with more then 400 rwhp less then him at 13 lbs of boost... They were also on Hayabusa though.DARK-5.0 said:I'm sorry bud, but you've got a lot to learn. I'm hoping you've already joined over at Turbomustangs.com and started reading. You car with 300 less hp will not eat his car alive. You are more than mistaken on that. That video was made at 13psi and his first time out on the track with that combo and first attempt at slicks. 13psi that car made 600rwhp and ran a 10.9 with some of the ****iest launching ever seen. So you're telling me at with 300rwhp you are gonna beat his 10.9. Thats comedy. You should also know that nothing changed in his combo between the video and him running his 9.87 at 152. He just got used to driving the car and upped the boost a bit. Still not going past 20psi. The car topped at 1013 in the vid at 30psi. He doesn't daily drive it at 30psi. I suggest you do lots of reading over at TM.com and see what other guys with you size cubes are running. If you want to run twins. Why don't you have someone build you a kit like Mike or Brian at B&G. I think you'd be better of with twins running a 427 mostly because it will take a large frame single set up to make power and still have street manors.
Jeremy
OinkAodeOink said:BTW, Give us an idea of what you want out of your car, and I or someone else can give you a better idea of what to do with your turbo situation.. I'll try to give some help.
I just HAD (bimmertech just bought it) a standard v2 sq-trim. a power pipe and my 331.TrophyHead said:Money pit- Just wondering what kind of supercharger are you running?
What does BG stand for? Im a little slow sometimes so i may have missed it? Do they have a website?nmcgrawj said:Brian at BG makes twin kits for 94-95's....351w based and 302 based engines.
BUT what i would do is contact Mike(oink on here) and talk with him. He knows his stuff and his work is just as good, if not better, than any other company out there. I definately think he is your best option...then just buy whatever turbo(s) you want, and go from there.
moneypit94 said:What does BG stand for? Im a little slow sometimes so i may have missed it? Do they have a website?
Redsnake2 said:Look at it like this instead of 1 turbo pushing 10-PSI, i can have 2 pushing 5-PSI each =10-PSI.
from personal expereince with superchargers, the negatives... BELT SLIPAGE. I would get 8-12psi depending on the day. Its harder on your crank. Superchargers are usually less efficient then turbos. They don't sound as cool... lol You can control boost from in your car if you want with a turbo. Have to change pulleys if you want with most superchargers.TrophyHead said:www.bgturbokits.com
Turbos are cool but you can do just as good if not better with a supercharger. I'm gonna get killed for saying that....![]()
you couldn't be more wrongif you knew you were gonna get killed for it, you obviously knew that you were saying something stupidTrophyHead said:www.bgturbokits.com
