ARP Head Bolts & Fuel Line Bracket?
  • Thread starter Thread starter Chuck D
  • Start date Start date Dec 20, 2005
C
Chuck D
50
Louisiana
Dec 20, 2005
  • Dec 20, 2005
I purchased ARP head bolts to use when I install the heads on my '87 5.0. The passenger side, front, bottom stock head bolt (behind the alternator) is actually a stud bolt. After this stud bolt is installed, a bracket which holds the two fuel lines is held on the stud part of the bolt by a nut.
The ARP head bolt set does not include a stud bolt. How do you mount the bracket that holds the fuel lines? I'm almost sure that it is not mounted between the head bolt and the head.
Thanks for your help in advance!
Chuck
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 20, 2005
  • Dec 20, 2005
It doesn't get mounted with the arp's, don't worry about it.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 20, 2005
  • Dec 20, 2005
Yeah, just let it rest. It is a stiffer mount anyways and it isn't going to do anything negative. I just let it ride against the head. Where it bolts onto the intake it has no problem staying in place...
C
Chuck D
50
Louisiana
Dec 20, 2005
  • Dec 20, 2005
Thanks for the info Grn92LX & 5Spd GT. :SNSign:
M
MatthewP
355
Calgary, Alberta
Dec 21, 2005
  • Dec 21, 2005
I threw the bracket away on mine - never had a problem.
-Matthew
jammer84_03
468
  • Dec 21, 2005
let it be...i got arp's and it works fine without..just doesnt look right....
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
