110 on top, and 100 on bottom will work fine. I know ARPs recommendation is less. The guys using high boost go a little higher to prevent the head from lifting.
One thing to keep in mind is what lube you're using when torquing the bolts. Moly lube is recommended, and that's the lube I used at my torque settings.
Chris
