Build Thread As Requested: Project Horse Manure
  • Thread starter Thread starter Boosted92LX
  • Start date Start date Feb 9, 2015
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
First Prev 35 of 38 Next Last
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 13, 2016
#681
  • Apr 13, 2016
  • #681
Boosted92LX said:
Today was part two. Lesson of the day was, in ancient car, carry tools. We had a loose hot post on the solenoid causing low voltage for the eec and smoke on the connection. I made a nine mile drive with tools to tighten the connection, and followed him to the corner store to buy a quart of oil. He came out, topped off oil, and she wouldn't spark. Zero. I let it cool about ten minutes and checked again, and it sparked like nuts... All connections seemed good, so i bought a tfi module, and we'll see if that does it. It starts fine now... Just dont know how long. Haven't checked codes yet...long day. Maybe tomorrow.
Ah the joys of a daily fox . eBay has Nos motorcraft tfi . I bought one to keep as a spare . If you need a motorcraft I have an extra distributor with one I could mail you the tfi.
Boosted92LX
5,721
4,244
224
Apr 13, 2016
#682
  • Apr 13, 2016
  • #682
I appreciate the offer man, i just put in a fresh chinese one. Let's see how it does. It was literally going from having spark one minute to nothing. Kept flip flopping. I'm hoping this is it, and not another bad connection somewhere. If this gets it, I'll buy a motorcraft throwdown.
Reactions: TOOLOW91
hoopty5.0
mechanicus terribilis
7,851
6,992
214
SW Houston
Apr 14, 2016
#683
  • Apr 14, 2016
  • #683
Dang man. Sounds like we both struck out yesterday.
smokin joe
746
45
49
Dallas,TX
Apr 14, 2016
#684
  • Apr 14, 2016
  • #684
You guys have really brought this car a long way. I absolutely love the color. I hope you get this issue worked out quickly.
Reactions: Boosted92LX
RaggedGT
Mod Dude
Jul 20, 2014
4,767
3,226
203
Taylorsville ky
Apr 24, 2016
#685
  • Apr 24, 2016
  • #685
Your boys car still surviving DD status?
Reactions: Davedacarpainter
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#686
  • Apr 24, 2016
  • #686
It made it a couple hundred miles and started spitting codes. It's gotten so bad it's in limp mode and I can't seem to get it out. We didn't have any of the smog stuff, so it went together without it. I'm trying to figure out how to satisfy the computer or maybe just buy a twEECer and turn the smog junk off. I did find the TAD and TAB solenoids unplugged, but there are no air valves for them to actuate, no thermactor piping in place... and no smog pump to pump the air. I cleaned up the connections on the two solenoids and plugged them in, and ran a vacuum line to the egr valve so the sensor could see it move, but still cant get it out of limp mode. It's also getting a temp sensor out of range code, and I don't know why.. I guess I can start throwing parts at it.. very frustrating. I just thought I hated this car before.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Apr 24, 2016
#687
  • Apr 24, 2016
  • #687
Non of the smog stuff not being there should put it in limp mode, mine was running for a good long while without any of that crap (except the charcoal canister to keep the garage stinking) just fine, and actually better than before I had the car tuned and that turned off at the ecu level.
Reactions: A5literMan
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#688
  • Apr 24, 2016
  • #688
Well, its thrown 81,82,85,95,51,21,94,44, and 33. It passes a cylinder balnce test.
The car is underpowered and wont rev past 4000 rpm. If anyone has any suggestion, I'm all ears.
I'm pretty good with mechanical stuff, Not so much with electronics. I prefer trouble shooting carbs.
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,634
203
Discordia
Apr 24, 2016
#689
  • Apr 24, 2016
  • #689
I'm pretty good with mechanical stuff, Not so much with electronics. I prefer trouble shhoting carbs.
Switch to a carburetor.......
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#690
  • Apr 24, 2016
  • #690
Yeah, I didn't say that. The thought did cross my mind, but i have so much money and time invested I may as well try to make it work.
That said, I've been tinkering with carbed engines since the mid 80s. I love em. I chuckle when I hear people trash carbed foxes... Half of them came with carbs, and I've had some insanely fast carbed cars.
Reactions: 90sickfox and Davedacarpainter
Davedacarpainter
Nov 28, 2015
11,833
11,634
203
Discordia
Apr 24, 2016
#691
  • Apr 24, 2016
  • #691
Just tweakin' you Allen, I'm a little bored since I ran out of welding gas....
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#692
  • Apr 24, 2016
  • #692
I wish some of these Stangnet EEC IV gurus would come over here and lay hands on this sick critter. I'm tired of buying parts for every code in the book.
Chuckman
1,604
1,002
173
st. louis, mo
Apr 24, 2016
#693
  • Apr 24, 2016
  • #693
51 and 21 (coolant and air temp sensors) are what I'd be worried with in that list. Make sure the engine is at proper warmup temp before running the scan. Could also be the 10-pin connectors, bad sensors (a bad ect sensor can cause some weird starting issues), or since they are essentially the same sensor could be swapped (I think they even share the same kind of plug).
EDIT: never mind, they're both coolant temp errors. Looks like it thinks it's too hot. Would definitely go to limp mode on that Imo. Make sure you actually have coolant flow through the heater tubes where it's mounted, and/or new sensor (assuming of course it's not actually running hot).
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#694
  • Apr 24, 2016
  • #694
Yeah, the boy is actually on the way to the auto parts store for those right now..
The coolant temp sending unit hasn't been working, I just tested the gauge, and it's good. The sensor for the computer is what I'm concerned with.. but we are going to get the gauge working and see if we are too hot or not.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 24, 2016
#695
  • Apr 24, 2016
  • #695
That sensor will make all kinds of go nuts. It's like that sensor , the maf , and 02s make that motor sink or swim .
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#696
  • Apr 24, 2016
  • #696
TOOLOW91 said:
That sensor will make all kinds of **** go nuts. It's like that sensor , the maf , and 02s make that motor sink or swim .
Well, i got an o2 code last round, and they're new too.. So, now we have a new coolant temp sensor, and I fixed the temp gauge. So, Sam is driving to town to buy gas and see if it'll line out. Did I mention I changed the tfi recently because it would randomly die and not spark? ..and a fuel pump... The list keeps growing.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 24, 2016
#697
  • Apr 24, 2016
  • #697
The joys of DD a fox . Atleast he's getting an education . Only reason why I haven't rushed to rip it all out and put the fast in mine is because I cut the salt and pepper plug off my harness and hard wired it and the car has never ran better . Just trying to enjoy it .
B.erazo712
235
46
48
Apr 24, 2016
#698
  • Apr 24, 2016
  • #698
You love em and you hate em. The joys of daily driving a fox, sadly I know it well.
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#699
  • Apr 24, 2016
  • #699
Hey tell me something. How come when i try to dump codes, disconnect the batt and all that, it won't come out of limp mode? Codes are all there still, and it wont rev above 4000.. I thought it would start all over???
Boosted92LX
5,721
4,244
224
Apr 24, 2016
#700
  • Apr 24, 2016
  • #700
maybe i need to clean the salt and pepper shakers, but i would still think it would let me clear everything.
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
