ASSEMBLY QUESTIONS
  • Thread starter Thread starter 83T-top
  • Start date Start date Oct 11, 2008
83T-top
45
  • Oct 11, 2008
First Question- I have a set of domed forged pistons with floating pins laying around and want to use them instead of the hyper pistons which are on my stock rods and they are pressed on. How would I go about doing this. I don't know if the forged piston can be pressed or not, would I have to get new rods or what?
Second Question- I have been reading on how to check piston to valve clearance with the clay method and it says not to use hydraulic lifters when checking instead use solid lifters. But the hydraulic roller lifters are longer then the solid lifter, so is there a certaint solid lifter to use? Thanks for any help you can provide.
83T-top
45
  • Oct 12, 2008
O.K. I think I have the connecting rod situation figured out. I'm pretty sure I'm going to have to use different rods cause the ones I have right now are pressed on and I have no way of finding out if the pistons can be pressed on.
But I'm still uncertain about what solid lifter to use for checking the piston to valve clearance, because the roller lifters are longer then solid lifters, unless I'm wrong, but i'm pretty sure the roller blocks have longer lifter bores for the roller lifters.
Anyone have any ideas?
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
