At what PSI are you rolling ?
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
I just checked my PSI and it's at ~ 25 PSI. in front and 30 PSI. in the rear :eek:
What's the best PSI for 245 wide tires in front and 275 wide tires in the back ? The max it says on the tire is 51! It's way too much.. what do you guys recommend ? The tires are Falken ZIEX-512.
Thanky!
stprorolla49 said:
i work at a tire place and we generally put 32 lbs in low profile tires such as those...
Same here. 32 is a good starting point. Mark them with chalk and run them and see how the chalk wears. If it wears on the inside faster you need to remove some air. If the outsides wear faster add some.
