  • 1994 - 1995 Specific Tech
Audio system problems
  • Thread starter Thread starter 99FiveOh
  • Start date Start date Jul 26, 2011
99FiveOh
2,051
20
99
J-Ville, FL
Jul 26, 2011
  • Jul 26, 2011
Before I swapped to the 5.0 in my 99 the sound system sounded perfect. Had a nice bit of bass to it (not bad for the stock non Mach 460 setup).
Now, for some reason I get lots of distortion even at mid volume levels. The dash harness out of the my old 94 that I used in this car had the Mach 460 amp and wiring. I installed the bypass harness on my stereo which basically bypasses any and all factory amps and it did the same thing.
I'm at a loss here. I'm probably gonna have to run all new speaker wires because I'm not sure if something is touching or not. I doubt it since it worked perfectly in both cars prior to the swap. Could there be an issue mixing the Mach dash harness with a non Mach body harness?
If anyone has access to the wiring schematics on a 94/95 vert without Mach 460 I'd love to see it. And wiring for a 94/95 coupe WITH Mach 460. I need to make sure there's no kind of crossover/capacitor installed inline somewhere.
Adam95GT
2,564
Burlington, NJ
Jul 26, 2011
  • Jul 26, 2011
Check the grounds in the kick panel
99FiveOh
2,051
20
99
J-Ville, FL
Jul 26, 2011
  • Jul 26, 2011
Which kick panel?
Adam95GT
2,564
Burlington, NJ
Jul 26, 2011
  • Jul 26, 2011
Drivers? maybe? I think....
99FiveOh
2,051
20
99
J-Ville, FL
Jul 26, 2011
  • Jul 26, 2011
will do. I'm pretty sure everything in that kick panel is bolted down the way it should be, but you never know!
Adam95GT
2,564
Burlington, NJ
Jul 26, 2011
  • Jul 26, 2011
Also i forgot... Are you using stock speakers still??? IIRC they are an awkward resistance and wont work with a normal aftermarket head unit without using the mach amps.
They are basically home theater speakers... 6ohms IIRC
99FiveOh
2,051
20
99
J-Ville, FL
Jul 27, 2011
  • Jul 27, 2011
Yes, I'm still using the stock speakers along with the factory amp from the convertible.
T
Need help locating 67 dash horn wire
  • THS70
  • Nov 21, 2025
1965 - 1973 Classic Mustangs -General/Talk- Dec 5, 2025
THS70
T
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
O
Manual to Auto Mach 1 Swap
  • Osnick
  • Mar 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 27, 2025
Osnick
O
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
