Auto Body Question...
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date Oct 21, 2006
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Oct 21, 2006
  • Oct 21, 2006
Super glue???
After taking the Stang in to the local auto body shop. I had them repair the prior owners **** up. Both doors would not close correctly. You had to lift them up a quarter of an inch and push in to close. Or pull a "Dukes of Hazard" via window.
After the repair, I asked him cost of fixing the molding or how one could go about doing a self repair. He told me to clean between the molding and door, and super glue it Sounds "ghetto" to me, like duck tape. Is there something perhaps one of you would use? Or is this guy not bsing me, and superglue would work?
Thanks
dgollem
20+ Year Stangneter
May 5, 2004
212
33
49
Waldorf MD
Oct 21, 2006
  • Oct 21, 2006
I have had some luck using RTV adhesive for similar things. Clean it the best you can, squirt or use a putty knife to get it between the molding and door and have some way to clamp or hold it in place. The setting time is usually 30 to 60 minutes. The RTV is not 100 % permeate like super glue or epoxy probably would be and is easier to clean up if some oozes out.
I'm not sure how the moldings are placed on from the factory, I've heard they use clips but they also might just use double side sticky tape. The double sided tape works but you have to buy the really good stuff and it can get pricey. Cost me $40.00 for enough tape to remount similar trim on a 93 Dakota. A tape of clear RTV is about 4 bucks.
Good Luck
spiff
17
Canada
Oct 22, 2006
  • Oct 22, 2006
The mouldings are double sided tape, And atleast on the 86 mouldings they have a thin tinny metal backing, and once that is bent they're wavy as hell and hard to stick down. I had a hell of a time gluing my temporary moulding down, it kept lifting no matter what I would use.
mustangjoe87
364
Harrison Twp., Michigan
Oct 22, 2006
  • Oct 22, 2006
No clips, duoble sided tape only. Clean both peices and then use either more tape or trim adhesive.
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Oct 22, 2006
  • Oct 22, 2006
pull it off. I used a putty knife and slowly worked it in to the tape while lightly taking off the trim and peeled it alll off. Remove the tape from the door and the moulding, then remove the thin metal peaice on the moulding, let it sit in a warm place for 1- how ever many you can stand w/o it and let it completely flatten out. Then just use double sided tape to adhere the two CLEAN sides and viola... done completely, no ghettoness and no waviness
D
Daggar
3,902
  • Oct 22, 2006
stykthyn
5,232
2,652
223
gainesville
Oct 22, 2006
  • Oct 22, 2006
sounds like you just had worn door bushings, it's actually pretty common for these cars.
double sided tape for the win
Turkey Sammich
Jul 12, 2006
154
Oct 22, 2006
  • Oct 22, 2006
I'll go with the doublesided tape, and let eveyone know the outcome. Thanks for all the input.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Oct 22, 2006
  • Oct 22, 2006
We do this a lot at work with fox stangs we are painting.
Take the molding off. Get a torch and heat the thin aluminum on the molding. Get a pair of pliers and peel the aluminum strips off the molding. Clean the surface on the car very well and clean the molding off well. As stated before this post use double side tape, DO NOT USE SUPERGLUE. I would grab a buddy to help you make sure the molding is aligned with the other other moldings.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 22, 2006
#10
  • Oct 22, 2006
  • #10
proform 2 part epoxy will hold it
Turkey Sammich
Jul 12, 2006
154
Oct 24, 2006
#11
  • Oct 24, 2006
  • #11
The double side tape works well. I've taken off and remounted. The most annoying time consuming part is removing the prior tape.
It's on there soild and I'm going to conduct a speed test. (Why a speed test? Why not).
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Oct 24, 2006
#12
  • Oct 24, 2006
  • #12
our 86 didn't have a tinny metal backing
get what ford used. double sided tape.
pull the trim piece off and clean both surfaces and stick them on. good as new
super glue= asking for trouble
DEFWISH
87
Wichita, Ks
Oct 24, 2006
#13
  • Oct 24, 2006
  • #13
if you pull it off, be very careful not to stretch it out, it stretches kinda easily. good luck
..edit.. don't use adheasive remover, it removes paint better than aircraft stripper...
Turkey Sammich
Jul 12, 2006
154
Oct 29, 2006
#14
  • Oct 29, 2006
  • #14
You've stated to remove the aluminum strips off the molding. I was wonder what this will complete
The issue I've come across is parts of the driver's side molding will not hold to the door straight & firm. If anyone has a solution to this problem please let me know. This simple project has turned in to .
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
4.6 question for those in the know....
  • LILCBRA
  • Aug 30, 2024
2K
2005 - 2014 S-197 Mustang -General/Talk- Sep 4, 2024
Adieu
N
Paint and Body Body Surface Rust.. Need Help.
  • Neptuned
  • Sep 9, 2022
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2022
General karthief
The Death of a Cobra II
  • 76_Cobraii_mustang
  • Oct 2, 2023
3K
1974 - 1978 Mustang II Talk & Tech Oct 3, 2023
2Blue2
