auto-manual convert
  • Thread starter Thread starter lawdoc
  • Start date Start date Jul 20, 2010
L
lawdoc
  • Jul 20, 2010
Has anyone out there converted a 5.0 auto to a tremec 3550? if so is there anything i should be aware of, and what is the best way to mount the clutch pedal?
foxforce33
82
Orange County, CA
Jul 20, 2010
  • Jul 20, 2010
I had a shop convert my '90 AOD to a 3550. I know it requires a different bellhousing than a T5, and I want to say the input shaft is a different length (maybe I'm wrong here). As far as mounting the pedals, I think it is pretty the same as doing any AOD to manual conversion (cable clutch). You will likely need a firewall spacer to get the action right, though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Jul 21, 2010
  • Jul 21, 2010
For the pedals, just pedals from a stick can and swap them in. They bolt right up. No spacers needed and the correct wiring is tucked up under the dash
BYRDPE
1,556
Memphis,Tn.
Jul 21, 2010
  • Jul 21, 2010
wow..did they use any grease or did they go in dry?
notchback
1,950
St Clair Shores MI
Jul 22, 2010
  • Jul 22, 2010
best tech article ever
WestCoastFords.com
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
