auto tranny problems
GT_green_GT
118
hi, i have a 95 gt, didnt get much answers out of the other forum. I thought id see what you all had to say. When i start out in drive it starts out in second gear and hesitates to shift. i have to let of and play with it then it will shift. The rpms will keep climbing. From third to overdrive it shifts fine. When i go through 1st and 2nd with the gear selector it will shift fine. Say i was in drive and i lay into it it will downshift and the gears will just climb sky high. Then i have to let off and it will finally shift. Any on have any thoughts?
could be valvebody crossleaks as well, your best bet is to have it analyzed. could be as simple as the mlps sensor. see if there are any codes first off. never hurts to drop the pan and check for debris. 2nd sprag is known to fail.
