  • 1994 - 1995 Specific Tech
auto.trans. difference
  • Thread starter Thread starter BLKBELT
  • Start date Start date Nov 4, 2007
BLKBELT
15
Florence S.C.
Nov 4, 2007
  • Nov 4, 2007
How can you tell an aode from a 4r70w ?There are no stickers on the trans.Thanks
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 4, 2007
  • Nov 4, 2007
What is the difference between the AODE and the 4R70W?
Mainly the gear ratios and the extension housing bushing and seal diameter
taken from Baumann Electronics website
BLKBELT
15
Florence S.C.
Nov 4, 2007
  • Nov 4, 2007
electric auto transmission
Thanks for the reply.What I need to know is how can you look at an aode and a 4r70w and tell one from the other.A guy has one for sale and some people say that it is an aode another person says that it is a4r70w?The guy doesn't know what it came out of but says that it is a 4r70w. Thank you
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 4, 2007
  • Nov 4, 2007
from what i could gather the only way externally is to measure the output shaft diameter and the tailshaft seal was different they seem to be very similar outside
toyman
1,944
54
79
Vernon BC
Nov 4, 2007
  • Nov 4, 2007
Like Punisher said the difference is in the gear sets. The ratios first to OD are
AOD-E 2.40-1;1.47-1; 1-1 .67-1
4R70W 2.84-1; 1.55-1; 1-1; .7-1
I would guess that one turn on the input shaft gear on the AOD-E in first will turn the output shaft 2.4 turns vs 2.84 for the wide ratio set.
If you are looking at installing it on a '94 or '95 with a 3:27 diff I would want the 4R70W. That would be the same as having a 3:87 diff gear yet still having the benefits of lower revs at speed.
Stanger007
2,015
Baton Rouge, LA
Nov 5, 2007
  • Nov 5, 2007
Don LaSota should be able to nail this one.
Here's a couple things I've noticed on the V6 4R vs the AODE:
* The transmission housing is different but I can't remember in what regard
* The 4R tailshaft has a larger diameter than the AODE
* The later 4Rs will have the VSS hole in the tailshaft plugged.
* The pans on the 4Rs can have a sump on them
BLKBELT
15
Florence S.C.
Nov 5, 2007
  • Nov 5, 2007
aode or 4r70w
Thanks for the info.I went ahead and bought it as a 4r70w,I hope that he didn't sell me a wolf ticket .I will try keep trying to find out what this trans came out of .If you think of any information please let me know. I will check out the ratio as soon as I can.
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
Engine How to identify EEC-IV
  • keel
  • Aug 17, 2025
Fox 5.0 Mustang Tech Sep 1, 2025
