Auto trans question
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Nov 12, 2011
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 12, 2011
  • Nov 12, 2011
Ihave a 4r70w trans in my car.Will L/T's for a manual trans work and also what is the ideal operating temp for the trans?I'm asking about the headers cause i found some for sale and want to buy them but not sure if they will fit a auto. peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 12, 2011
  • Nov 12, 2011
Nobody??? Peace
John
W
wizwrath
34
  • Nov 14, 2011
I can assume that you are refering to your Fox, in all the years ive been doing this, the auto trans needed a special header (yes I got both auto and manual foxes) and with you especially going to the larger 4R70W trans, im sure you would need a auto trans headers. I know that MAC has them, there is good and bad reviews on them (I run them without issues though). And (my opinion) is that the suto trans should be at least around 160-170 degrees, and anything around 190's and up is getting to hot for performance applications, I know that the new cars run around 210 or so degrees so go figure.....but I know that every 5-10 degrees hotter, it degrades the life expectency dramatically.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 14, 2011
  • Nov 14, 2011
Thanks very much!
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Nov 14, 2011
  • Nov 14, 2011
100* over ambiant temp is where you really dont want to go over...
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 16, 2011
  • Nov 16, 2011
If i'm reading correctly i want to stay around 160-170 degrees and not go no more then 190 for strip use?I have the controller for the trans also.ANother thing, my cooler is stock (as far as i know) and it also routes threww the radiator..Should i get an aftermarket cooler instead of the stock one? Oh yeah the headers i was looking into was for a manual peace
john
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
