Autolite 4100 Trouble
Moms Mustang
I have a 1966 mustang 289 with a 4100 Autolite carburetor on a stock ford intake. Carburetor number is C5ZF-F. I cannot get the engine to idle smoothly. I am eliminating the ignition system since the distributor, points, condenser, cap, rotor and plugs are new. I tried a spare set of plug wires with no change. I also tried a spare coil with no change. I can find no vacuum leaks and have about 19" of vacuum. Is there something I could have done wrong on the carburetor rebuild causing a rough idle. Thanks for your assistance.
  • Sponsors(?)
horse sence
That $5 hooker turn out to be a guy
4,476
233
Wile Coyote's stunt double
They are known to wear in the butterfly rod openings ,squirt some carb cleaner on the butterfly rod while it is running and see if the idle changes
Reactions: 1 user
rbohm
SN Certified Technician
Apr 12, 2002
6,698
551
204
62
tucson,az
H makes a good point. if there is no change, try advancing the timing a few degrees.
Reactions: 1 user
