  • SN95 4.6L Mustang Tech
Automatic shifting weird
  • Thread starter Thread starter mustang jack
  • Start date Start date Jun 25, 2005
M
mustang jack
10
Maryland
Jun 25, 2005
  • Jun 25, 2005
Hey All,
I have an 01' Gt with an automatic and i am finding out that first gear does not last a long time.It seems like it is shifting out of first way too quick.And to be truthful when it goes into the other gears it shifts weird.Does anybody else notice this?Is there anything i can do to change the shift points or duration?
Thanx,
Jack
OUR01GT
121
EAST CENTRAL OHIO
Jun 25, 2005
  • Jun 25, 2005
You can always buy a programmer and change the shift pionts and pressure. Be sure to add a good tranny oil cooler if you modify the tranny in any way. Also, when was the tranny oil and filter changed last?
M
mustang jack
10
Maryland
Jun 25, 2005
  • Jun 25, 2005
Have not changed the tranny fluid or filter yet.She only has 23,000 miles. Maybe i should huh?
P
PEWTERPONY
829
NE Atlanta
Jun 25, 2005
  • Jun 25, 2005
No you are fine. Unless you stay on the gas, the car will up shift and downshift like a bitch. You don't need to change your fluid untill you reach 30thou. Im about to reach 60 and will have my changed again.
Tunr od off and noticed how much better it behaves. One of the downfalls of owning an automatic, it shifts when it wants to
Still love mine!
OUR01GT
121
EAST CENTRAL OHIO
Jun 25, 2005
  • Jun 25, 2005
I do reccomend a shift kit if you're not happy with it's shifting manners. You will find many pro's and con's in this forum about shift kits but I have had no issues with mine.
02LaserRed2V
379
Augusta, GA
Jun 25, 2005
  • Jun 25, 2005
mustang jack said:
Hey All,
Thanx,
Jack
What are your mods? Do you have stock gears or did you swap for another ratio?
I had the same or similar problem with my auto after installing 4.10 gears with a Diablosport Predator tune. 1st gear would last just a split second, then shifts to second. And while cruising (30-45mph), the tranny would shift into overdrive way too soon. At times, my car felt like a three-spreed automatic since 1st gear was basically non-existent.
Since then, I've replaced the Predator tune with a custom SCT tune, and the shifting has improved greatly. I actually "have" first gear now. And at WOT, it shifts into second at 5700 RPM.
Red03Mustang
373
  • Jun 26, 2005
4.10 gears are so much shorter that it will run through 1st quick anyway. The only way to make an auto hang in first longer is to gas it more.
Unless you tune it, of course. WOT shift points can be tuned with a Predator, but I hear that the XCalibrator 2 tunes Partial throttle shift points also, so that could be handy. I have a diablosport predator, and I like mine for the most part. I hear that the next revision for the Predator will allow users to adjust partial-throttle shift points as well.
My GT auto does have jerky/choppy shifts sometimes. I guess that's because the auto is designed more for performance than for smoothness. Which, to be honest, I don't mind that much. After all it is a Mustang. I've posted some threads about the smoothness of my shifts too, but I decided to either get a manual if I want different shifts, or just be happy with what I have, because it's not like it's aweful.
02LaserRed2V
379
Augusta, GA
Jun 26, 2005
  • Jun 26, 2005
That's the thing. In the past, mine would shift into second even faster if I give it too much gas. I suppose the Predator tune I had wasn't the best. *shrugs*
But mine now drives totally different considering the shift points on partial throttle has been changed. Tim@MPH had it tuned where first doesn't go into second so quickly during normal driving.
propellerhead
1,541
"but what's with the but shots?"
Jun 26, 2005
  • Jun 26, 2005
Red03Mustang said:
... WOT shift points can be tuned with a Predator, but I hear that the XCalibrator 2 tunes Partial throttle shift points also, so that could be handy. I have a diablosport predator, and I like mine for the most part. I hear that the next revision for the Predator will allow users to adjust partial-throttle shift points as well.
As Red03Mustang mentioned, the Predator can adjust your WOT shifts. The Predator's tune does nothing to your part throttle shifts. For now, it will take a custom tune to get the part throttle shift points changed. I have one on mine and by the way it shifts, people think I have a 5-speed. My gears hold to 2500-3000 RPM during normal daily driving.
Keep in mind, the shift schedule is all computer controlled and is based on SPEED VS THROTTLE POSITION.
Maybe someone with an Xcal2 and an auto trans can tell us more about the part throttle shift point adjustments.
M
mustang jack
10
Maryland
Jun 26, 2005
#10
  • Jun 26, 2005
  • #10
I have no mods on the car eveything is bone stock.I really don't want to modify the car.I have been thinking about a programmer.What rear gear does this car come from the factory?
Jack
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
