I'm having some trouble with the automatic transmission in my '95 GT Convertible. It doesn't downshift during normal driving from second into first until you are almost completely stopped. It nearly stalls every time you slow to stop until it downshifts. Also, if you are stopped and shift into second gear manually (it only does this if you shift into second), the transmission will actually shift into second gear while the car is sitting still and the engine will stall. And one last thing, when driving along in OD, if you press the pedal down for the transmission to downshift and accelerate, when it downshifts it loses the gear for a moment and the engine revs until it finds third gear.
Now, it operates normally under all other circumstances. No slippage, no mushy shifts.....any ideas???
