Automatic transmission
  • Thread starter Thread starter humaxxx
  • Start date Start date Jan 14, 2009
H
humaxxx
35
  • Jan 14, 2009
Hello,
We have rebuild a C4 Automatic transmission. Everythink is perfect except the reserve. When you put the car in reserve the transmission doesn't respond. But if you give the car a little throttle the transmission responds and gets in reserve!!!
Can somebody tell me whats wrong!!!
Can somebody also tell me how this transmission works....witch clutch and band are engage in every gear!!
greetings
Freek (from Holland)
D
D.Hearne
11,730
south louisiana
Jan 14, 2009
  • Jan 14, 2009
Sounds like it's low on fluid. Does it do this in drive too?
H
humaxxx
35
  • Jan 15, 2009
The problem is solved..........it was the servo how's engage the reverse band!!!
the rubber of the servo was hard and seals not properly!!
brianj5600
1,964
Middle TN
Jan 15, 2009
  • Jan 15, 2009
Park = no band and no clutch
reverse = reverse band and direct clutch
neutral = no band and no clutch
drive = 1st gear is forward clutch, 2nd gear is forward clutch and intermediate band third is forward clutch and direct clutch
2= forward clutch and intermediate band
1=forward clutch and reverse band
I would check the reverse band adjustment too. Tighten 120 in.-lbs., back off 3 turns counterclockwise
H
humaxxx
35
  • Jan 18, 2009
hello
Why is the 1 gear different in the drive or 1 ??????
brianj5600
1,964
Middle TN
Jan 19, 2009
  • Jan 19, 2009
By applying the reverse band it gives you engine braking in 1. That is the only difference. There is not any increase in TQ capacity. Most manual valve bodies do not apply the reverse band in 1 and coast on decel.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
