Automatic Transmisson ???'s
BlackLX5.0
76
The tubes that run off from the side of the transmission to the front of the radiator, does the transmission lines go from like the top of the transmission to the top of the radiator and the bottom one to the bottom of the radiator?
Thanks :SNSign:
That's a good question. I just took a set out of my car for the T-5 swap. I'll look at them when I get home and give you an answer if nobody has.
As long as the return line on the radiator is coming from the bottom part on the radiator (so as not to have to flow against gravity up the cooling chamber,) you're good.
Don't recall offhand which is which on the tranny. :shrug:
