AutoMeter tach?
  • Thread starter Thread starter bluebeast
  • Start date Start date Mar 6, 2004
bluebeast
215
Mass
Mar 6, 2004
  • Mar 6, 2004
i installed my autometer sport comp tach on my car. i followed the directions how they told me to BUT i have a problem. When my car is idling the tach reads about 3k as i go the tach jumps all over the place until my stock tach reads 3k then the autometer one jumps down to 3k and works fine until i go below 3k. Basicly anything below 3k my tach goes nuts. any ideas on what could be wrong. i also have a whole jacobs ignition thing kinda like the msd but jacobs i also have a jacobs ultra coil. The instructions only mention the msd.
thanks
eric
Black331Stang
1,485
Long Island, NY
Mar 6, 2004
  • Mar 6, 2004
probably not what u looking for but only discrepancy i have invloving 3000 is that i cant set my shift point any lower than about 3400. i dunno if its normal or not
Sgt.5point0
258
Rapid City, South Dakota
Mar 6, 2004
  • Mar 6, 2004
I don't know a lot about the aftermarket ignition products but I think some of them have a specific spot on the box that you're supposed to run you tach signal wire to instead of the coil.
88stangmangt
2,332
Stafford,VA
Mar 6, 2004
  • Mar 6, 2004
are you sure you have it set for a v-8 rather than a 6 or a 4? they send out diff igniotn signals.
Sgt.5point0
258
Mar 6, 2004
  • Mar 6, 2004
Thats true also... I think on the Autometers you have to actually cut wires at the back of the tach to go down in cylinders. I hope you didn't do that
bluebeast
215
Mass
Mar 6, 2004
  • Mar 6, 2004
nope i did not cut any of the wires on the back. it is set up for an 8 cyl. could it be my ground? do u have to ground it to the engine like it says?
Sgt.5point0
258
Mar 7, 2004
  • Mar 7, 2004
Yeah you could try moving the ground... If it does the same thing when you move the ground then that's probably not whats wrong. Did you check your Jacobs Ignition for a tach outlet?
88stangmangt
2,332
Stafford,VA
Mar 7, 2004
  • Mar 7, 2004
ya you might need a tach driver.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
