  • 1994 - 1995 Specific Tech
Autometer water temp. gauge help..
  • Thread starter Thread starter xYoung347x
  • Start date Start date Jun 19, 2004
xYoung347x
382
  • Jun 19, 2004
I just got my new gauge in and now Im clueless. Not really but I just want to do this right so can some one break it down for me? Where do I get the ignition switch from? Where do I put the twist-in light? Thanks
-Young
94TURBO5 O
2,509
VA
Jun 19, 2004
  • Jun 19, 2004
Get ignition from your fuse box and tap the light wire into your headlight switch.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 19, 2004
  • Jun 19, 2004
I used a power tester to see which wire under the dash had power. My clock was bad, so I used that wire for the dimmer. I ran a ground along with the sending wire through the firewall together, then grounded it with with a screw on the side fender wall, and continued with the sending wire to the sending unit, which I installed in the lower intake. I moved the stock one to the water neck screw (there is not a screw on the stock water neck, but there is on after market ones.)
Good Luck
RC
Venom351R
4,548
41
98
MAINE
Jun 19, 2004
  • Jun 19, 2004
-Young
should be a hole for it right in the back of the guage, just turn it and it will pop out. Use the Green or Red bulb covers to give it a diffrent color durning night driving. I used the Red one on mine.
PS: since were talking about autometer temp guages does anyones guage ever stick Somestimes even after driving long enough for the temp to be up to 180 it still reads 0 on the guage. Once I get on it up to about 3,500 RPM's then it kicks in and the temp guage goes up. It dosent always do this but seems to a few times a week. Any Ideas
Venom351R
4,548
41
98
MAINE
Jun 19, 2004
  • Jun 19, 2004
94GTLaserRC said:
I used a power tester to see which wire under the dash had powerRC
Same here, we used the dimmer for the clock for the light to the guage as well.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
