Alright, well the problem is simple to say, the cigarette lighter and aux power port on my 97 GT are both dead.
Unfortunately it gets harder after that. The fuse is fine, that's the obvious first check. There is 12V to the hot side of the fuse receptacle, and the fuse shows continuity (the fuse for this is a 30amp, I also tested switching a 25 amp to verify that it wasn't the fuse and it's not).
So anyway, I pulled the shifter panel out and tested the connector itself, there is no power, there is no ground. So that says to me that the line is completely disconnected/broken somewhere.
Has anyone seen this or have any idea why this may be? From what I can tell (and reading the wiring diagram), it looks like the wiring comes from the aux power port, goes down the drivers side of the console, meets up with the cigarette lighter wiring, then continues on to the back of the console somewhere. Does anyone have any experience with this wiring and where I may look to check it's connections?
I'm at a point now where I'm about to have to start yanking things out to follow this wiring inch by inch to see what's wrong, and I'd really rather not have to do that. Thanks in advance for any help.
