- Dec 28, 2005
- 41
- 0
- 0
OK. So, I couldn't wait to install my new Borla Stingers since they arrived today and it was decent weather. So, although I didn't have another pair of hands to help, I was told I could do it myself in 20 minutes. I called an installer and he said it was easy and that he would charge $80 for installation. So, I decided to go it alone.
When I removed the hanger brackets and put them on the Borla mounting rods, everything went fine. A few of the factory bolts were hard to reach but I managed. I had trouble getting the pipes to seal up but I just torqued down hard on the clamps and got it tight. However, the tip coming out of one side is very close to the side of the cutout in the rear spoiler and is almost touching. The other side is almost perfectly centered. How can I adjust the position of the one that is not centered? Do I need to remove the entire thing and start over again?
Is it common to have to bend the mounting rods to get the tips in the centered position? I certainly do not want to have to bend the rods if not necessary. Needless to say, this whole installation took a few hours and I am still not happy with the alignment. Please help!
By the way, I am sure this issue must come up with other manufacturers of mufflers, so don't hesitate to chime in if you think you can provide some good advice. Thanks!
Is it common to have to bend the mounting rods to get the tips in the centered position? I certainly do not want to have to bend the rods if not necessary. Needless to say, this whole installation took a few hours and I am still not happy with the alignment. Please help!By the way, I am sure this issue must come up with other manufacturers of mufflers, so don't hesitate to chime in if you think you can provide some good advice. Thanks!
