  • 1994 - 1995 Specific Tech
axle dampner
  • Thread starter Thread starter 808SN95
  • Start date Start date Dec 24, 2004
808SN95
25
  • Dec 24, 2004
How much do you need the axle dampner on the rear suspension? I have 275/45/17 nittos on a 17x11 thorq thrusters on the rears, they use to rub the axle dampners. When I got the car lowered I asked for the axle dampners to be removed. A guy at Ford said that the axle dampners don't do anything. It's suppose to prevent your axle from turning. I've had situations where I'm doing like 90 mph on the highway and I approach some bridge where there's little lip where the concrete meets the asphalt. The rear end just jumps up, it's almost to the point of losing control of the car. I have kyb adjustable shocks all around.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 24, 2004
  • Dec 24, 2004
You don't need it most remove to make their car lighter the ford tech is correct. I think it's called the "dog bone". Yank that bad boy out.
hillie16
9
108
Dec 24, 2004
  • Dec 24, 2004
It's NOT the dog bone, they are the horizontal shocks in the rear end, and I wouldn't ditch them until you get some quality aftermarket lower control arms. They keep your rear axle from twisting.
baglock1
The Bartender
6,612
Space Coast, FL
Dec 24, 2004
  • Dec 24, 2004
"Twisting" really isn't the right term. Those dampeners are the quad shocks and are there to control wheel hop. Wheel hop occurs as the rear tires repeatedly lose and regain traction. It's caused by flex in the control arms.
In may situations, you can ditch them all together, but it's always best to wait until you've installed quality aftermarket LCAs first.
larrendeuce
649
Southern NJ
Dec 24, 2004
  • Dec 24, 2004
I'm taking mine off when I get a torque arm and panhard bar. Otherwise I wouldn't. Even with aftermarket control arms the design of the suspension included quad shocks.
baglock1
The Bartender
6,612
Space Coast, FL
Dec 24, 2004
  • Dec 24, 2004
I'm of the the philosophy that unless there's a reason for it, get rid of it (the K.I.S.S. rule). But you're right. The factory design included the quads but that doesn't mean that you need to keep them, especially considering Ford's design methodology:
"Sir, we have a problem with wheelhop in about 10% of the cars. Should we fix the problem?"
"No, just slap something on there to hide it and call it a day."
In my opinion, I think they have an appreciable effect on only a few of the Mustangs out there.
Mine have long since been removed, but that was only because I was installing LCAs and coilovers at the time. YRMV
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Drivetrain 8.8 Axle Worn 0.016": Use Stock Bearing or Repair Bearing?
  • Eulers
  • May 26, 2021
3K
Fox 5.0 Mustang Tech May 27, 2021
HemiRick
Drivetrain 33 spline SN axle with ABS and parking brake build
  • revhead347
  • May 12, 2020
4K
1994 - 1995 Specific Tech May 12, 2020
revhead347
