Axle Question 5 lug
  • Thread starter Thread starter backfocus
  • Start date Start date Feb 25, 2006
backfocus
254
Little Rock, AR
Feb 25, 2006
  • Feb 25, 2006
Axle and Locker Question
So I am trying to figure out what has been done to my car. I bought it several years ago from a guy who gave me documentation on what had been done to it, or so I thought. He didn't do the work on it, but had been taking to a new mod shop in St. Louis. Needless to say, as I have went to replace items I have found out that the mods that were supposed to be done were, but not always with the parts listed on the sheet that was givin to me.
So now my question, the car has a 5 lug swap with Licoln rotors in the front and back. I thought that it still had stock axles, and had the flipped Licoln rotors in the back, but now I have new 17 x 9 wheels (with what I thought was the right backspacing) that I am want to put on and they stick out to far. So I tore out the axles to measure them, I am suspecting now that I have Licoln axles. [I]They measure just shy of 30 1/2". I am measuring from the front axle hub to the end of the shaft, is that the correct way to measure them?? [/I]
I have been reading on here about axles.
Stock= 29 5/32"
SN95= .75" longer
Licoln= 1.25" longer than stock
If I am doing my math correctly I have the Licoln axles. Can some on please confirm for me.
I have a locker question too, but it will have to wait until tomorrow, because I have picts needed to post.
backfocus
254
Little Rock, AR
Feb 25, 2006
  • Feb 25, 2006
Ok guys here are some pict of my rear diff. I am not that experienced with gears and lockers, so can you tell me if this is a locker? (Auburn)... maybe??? I was told it had a locker in it. I have been comparing picts with others on a here and other sites, mine does look different that what I think is stock.
Are you guys buying Friction modifier at a parts store, I can't find it here? I am putting synthetic back in it so do I need it with synthetic fluid?
Finnally does, anybody know the about my original question. Axles length?
Thanks for the help.
Saleen0679
876
24
49
Yakima, WA
Feb 25, 2006
  • Feb 25, 2006
Definitely looks like an Auburn.
You should be able to find friction modifier at any parts store. If not the Ford dealer should carry the stuff.
Most synthetic gear oils do not require friction modifier. Check the bottle of your chosen selection to be sure. FWIW Auburn Gear recommends a non-synthetic gear oil.
Not sure about the axle length.
backfocus
254
Little Rock, AR
Feb 25, 2006
  • Feb 25, 2006
Thanks for the conformation on the locker and the heads up on the synthetic, I just confrimed that on aurburn's website 80W 90 and friction modifier. Guess I will try Ford locally for the modifier or order it, parts store here don't carry it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 25, 2006
  • Feb 25, 2006
Can you take a picture of the rear brakes themselves? I'll be able to tell you if it's the stock lincoln or modified lincoln setup just by looking.
Need pics of the axle brackets specifically. But take some from different angles.
Most likely, if 17x9's stick out too much, they are Lincoln axles. If you get some fox lenght axles, you can modify the brakes yourself to suck them in.
marine_2003
427
Lake County, FL
Feb 25, 2006
  • Feb 25, 2006
I just put in an Auburn, used Royal Purple Synthetic Gear Oil and still ran a bottle of Amsoil Slip Lock, modifier. No problems.
backfocus
254
Little Rock, AR
Feb 25, 2006
  • Feb 25, 2006
Here are picts of the brakes. I am sure that they haven't been flipped. Been doing alot of reading on the flip
If I decide to change to the SN95 brakes out back will my master cyclinder be fine, I its the big one that ford sells with the 73mm upgrade? Flipping the Lincolns seems like alot of work and I haven't read anything on how to get the emergency brake to work that way.
One last thing I mounted the 17 x 9s up front and they fit on the spindle great, but they also look to stick out. I thought that the Lincoln setup retained front track, just had the bearing hub sticking out. So needless to say the wheels at the moment have 275/40s on them and I have 255s I will be putting on, but it looks like the wheel actually sticks out past the fender in the front to. They are Steeda ultra lites.
Hope these pict are good enough, some I had took already.
Maybe Mavrick can help me he has a Lincoln setup in back. I think....
trbkrb
1,976
Houston, TX
Feb 26, 2006
  • Feb 26, 2006
The rears are for sure not flipped. You have to remove the dust/splash shield to flip them. It took me a couple of hours to get all the grinding and such done on mine to modify them. Plus they were much cheaper than the SN95 setup at the time.
Regarding the ebrake, I fixed mine to work by bending the bracket on the caliper to clear the lower control arm mount. Along with modifying the ebrake handle, the brakes work just fine. Here are some pics if you want to use the flipped brackets. Stock on the left, bent on the right. I cut the lips at about 2 and 9 o'clock in picture 3 so the brackets would bend:
http://statefilingsoftware.com/pictures/ebrake1.jpg
http://statefilingsoftware.com/pictures/ebrake2.jpg
http://statefilingsoftware.com/pictures/ebrake3.jpg
And one of the whole ebrake assembly installed:
http://statefilingsoftware.com/pictures/ebrake4.jpg
Oh, and on the fronts, I think the rotor hat is a bit taller on the SVO/Mark VII rotors since the SVO wheels have a deeper backspacing due to the wider rear. Kind of like the 93 Cobra wheels and rotors. Don't know for sure, but it makes sense to me especially if the wheels are sticking out.
Good luck!
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 26, 2006
  • Feb 26, 2006
You are right. Those are stock non-flipped LSC rear disks.
If you do decide to go SN95, you'll need to run the Fox axles (in 5-lug) with one of North Cobras rear braket setups to fit 17x9's. This way the wheels will be pulled under nicely. However, you cannot use the MC you have now.
Seems to me the best thing to do with the least amount of work is flipping the brackets and buying some fox-lenght 5-lug axles.
As for the fronts, you are right, the SVO rotors are simply Fox rotors with another lug. There is no offset change or hub change. A 275 is a large tire for the front, so you might want to think about lowering it to a 245/255.
Just curious, what wheels did they come with and how did those fit? Any pics?
purple87lx
24
#10
  • Feb 26, 2006
  • #10
Hmmmmmm lincoln axle shafts in the back????? I never heard of doing that.If you continue to have problems get 2 DRIVER SIDE axle shafts out of a mid to late 80's ranger,thats what i did my 5 lug con. with and iv had no problems.
backfocus
254
Little Rock, AR
Feb 26, 2006
#11
  • Feb 26, 2006
  • #11
Thanks for the help guys!
Not sure what I am going to do to fix my problem yet, may just flip the lincolns over for now. Not sure about the front though I am going to have to mount the 255s I have on the wheel and see what it looks like. I put the wheels, (which already had 275s on them) on the car just to see how they fit. Already knowing the the tires were to big, but I was worried about the wheel clearance at the time, just haven't had the 255s mounted yet, but I wanted to stay with 275 out back.
The problem with the front, and the new wheels, is the wheels themselves look to be out to far, say 1/2". trbkrb what tire and wheel combo do you run?
Here are some old picts of the car and the old wheels. They are 16x8 Elites backspacing is 5 3/8". Tires are 225/50 and 245/50. The chrome is chiped and coming off and I wanted to replace them. Hard to tell with these picts, but even with these tires I thought that the wheels always stuck out a little to far in the back.
What MC would I need for the SN95 setup?
trbkrb
1,976
Houston, TX
Feb 26, 2006
#12
  • Feb 26, 2006
  • #12
I have 17x8 Bullitt wheels front and back, with the stock 245/45/17 tires right now. I don't like how the rears are tucked in. I originally planned to use 17x9 wheels, thus the flipped brake setup. I had 255/40/17s on it before and they fit great. I plan to either get some 17x9 replica wheels for the back and 275 tires, or go the SN95 axle route and try to use the Mark VII brakes. One guy on Corral (RedSE) modified his Mark VII brakes (he had them machined down) to fit the SN95 axles, and I might try that since I already have the brakes and a set of SN95 axles in the garage.
Here is an old pic with the 255's
http://statefilingsoftware.com/pictures/87lxrear2.jpg
another pic of the brakes with bent ebrake bracket:
http://statefilingsoftware.com/pictures/rbrakes1.jpg
And a rear view straight on with the 255s, stock width, on 17x8 wheels.
http://statefilingsoftware.com/pictures/rbrakes3.jpg
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 26, 2006
#13
  • Feb 26, 2006
  • #13
It's the rear disk setup that comes stock on the 84-86 SVO and 87-93 Saleen Mustangs
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 26, 2006
#14
  • Feb 26, 2006
  • #14
Here's a shot of my car back when i ran Mark 7 front rotors. It's an 17x8 Cobra wheel with a 235 tire on it.
Pretty tucked in. Later when i swapped to SN95 disks up front, the offset hasn't changed.
If you go to SN95 rear disks, you may or may not need to change the MC. it all depends on the pedal feel. The rear calipers are 38mm pistons while the lincoln setup uses 54mm pistons. The smaller calipers may give you a harder pedal. A 94-95 GT MC may work for you, but it's hard to say if you keep the stock Mark 7 front setup instead of swapping to SN95 up front as well.
WHat 17x9 wheels are you running, and what is their offset and BS?
backfocus
254
Little Rock, AR
Feb 26, 2006
#15
  • Feb 26, 2006
  • #15
My new wheels are STEEDA Ultra Lites. I got a good deal on them from a guy $600 for 1 year old wheels not a scratch on them with almost new 275/40 Nittos mounted on them. Backspacing is 6" not sure the offset. I had been talking with Almostsock and they are the same wheel as the ROHs and that is what he runs, but he also has a BAER setup for brakes. I know mine stick way out compared to his, even on the front, Refering to the wheels not the tires. I found some 255s locally new for cheap, that is what I want to use on the front.
backfocus
254
Little Rock, AR
Feb 26, 2006
#16
  • Feb 26, 2006
  • #16
trbkrb I noticed in those picts your shock is turned sideways compared to mine. Is that part of the Lincoln Flip or am I looking at the pict wrong. I don't remeber reading about a shock flip.
trbkrb
1,976
Houston, TX
Feb 26, 2006
#17
  • Feb 26, 2006
  • #17
It is mentioned somewhere. I think I got it from Matt Bobbitt. It give a hair more clearance, and I believe it is actually the way the older Fox shocks are mounted (like pre 85 or so). I tried it just to make sure it would have enough clearance for the ebrake, but I have had a problem with the bolts coming loose. Probably needs some locktite or double bolts. I had actually taken the wheel off to tighten the bolt when I took that picture. I don't think it is necessary, and I will probably put the bracket back on when I replace my control arms in a few weeks.
Thomas
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
