  • SVT Tech Forum
b head porting vs b to c head swap
  • Thread starter Thread starter doc stang
  • Start date Start date Mar 8, 2010
doc stang
57
  • Mar 8, 2010
hello, i need some advice regarding a 98 cobra
i am building it up for american iron, road racing action, and it needs to remain Naturally Aspirated.
i need about 350 rwhp, and 360 tq, which will give me just a little wiggle room, depending on her final weight after the cage, and all.
i think i want to do some b heads with port/polish/valve job, and cams.
looking for advice.
the car will NEVER see forced induction
it may, down the road get a built short block with higher CR, and stroker crank (+/- on this),
maybe never, if the heads/cam/intake get me where i need.
what do i need to get and do. to reach my goal
i am looking to maximize are under the curves, not for peak numbers.
i want a long flat torque curve, and to be able to use as much rpm band as possible.
this will be a strictly road-course racing car.
does it matter what 4v head i start with???
cobra vs Lincoln Mark VII, vs (do navigators come with some DOHC / cobra-compatible heads?)
how much of a P/P? i don't want to go too wild, and take a step backwards, considering i wont be adding FI
should i even port em at all, and just do cams?
oh yeah, where are we right are now:
stock power plant with :
LTHs, off road h pipe, and flomasters with dumps/turn downs
smog pump/egr delete,
a K&N filter,
and steeda 10% UDPs, and an aluminum DS,
yielded a disappointing 287/283.
not sure how much he left on the table, if any
thanks,
doc
i DID just read the sticky, about heads
wow,
a lot of info, and things to consider.
in the 1st part of my post, i indicate i had been planning on staying with B heads, since that is what the car has,
and by doing so i dont have to switch from a return to a returnless system (or di i have that backwards?)
after doing a little more reading. . .
as i now begin to consider a b-head to c-head swap. . .
i am even more confused as to what will be the easiest/cheapest to reach my hp/tq goals, naturally aspirated,
doc
jeremy canter
402
Orange County , NY
Mar 8, 2010
  • Mar 8, 2010
I too am looking in to doing some very heavy head porting on my b-head for my 98> I have not yet searched the web but will start later today to see if I canget any tips or hint's > . My way of thinking was to cut the wall out of the intake and make a b-head intake port look more like a c-head with a nice smooth polish job on it . any thought's on that idea? > what sticky did you read on 4v heads > I must have missed it .
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
  • SVT Tech Forum
