Will a B&M Shifter work in a 2001 GT with auto trans?? B&M lists it for Mustangs up to model year 2000 (part number 81001), but not 2001+. Is this because of the OD button? Could I use this shifter if I relocate the OD button to the dash or console?
Also, how exactly does this shifter work? Can you just put it in D and drive normally when you don't want to shift? Or do you have to "ratchet" through all the gears?
Ultimately, I will probably be going with a Street/Strip valve body from Performance Automatic and am looking at upgrading/changing the shifter.
Thanks,
WES
Thanks,
WES
