  • 1994 - 1995 Specific Tech
Back again - rough running
  • Thread starter Thread starter crazyhorse95
  • Start date Start date Apr 11, 2005
crazyhorse95
136
St Louis
Apr 11, 2005
  • Apr 11, 2005
Okay guys I'm back with the same problem - but definitely getting worse. The car is running very rough between like 900 and 1500 rpm's. At idle it's fine, but if I barely set my foot on the gas and hold it at about 1100 rpm's the car just shakes like hell. When I push past it seems fine, though I'm not sure if it's just not as noticeable at higher RPMS.
Last night I changed the PCV Valve, cleaned the MAF, put new wires and plugs and cap and rotor on. No change. :damnit:
110,000 miles 95 GT, K&N air filter
Any ideas?
M
_MATiC
140
El Paso, TX
Apr 11, 2005
  • Apr 11, 2005
i dont know if this will help but have you changed out ur fuel filter? my car runs pretty ugly in the lower rpm's but i think that's becuz my timing is off..
crazyhorse95
136
St Louis
Apr 11, 2005
  • Apr 11, 2005
Fuel Filter
That's next on my list, was too late last night to deal with. So not yet.
JJ95GTID
1,141
Phoenix, AZ
Apr 11, 2005
  • Apr 11, 2005
How's your harmonic balancer (dampner)? If it is the original unit it could be coming apart and causing a imbalance that shakes real bad at the rpms you are stating. Also, the EGR has a green vacuum line going to it. Pull it off and feel if it is dithering(pulsing) from the green hose. If that is good you could remove the EGR itself and see if it is operating correctly. You should be able to 'lightly' apply vacuum to the nipple that the green hose is attached to and hear the valve open and close. If it is stuck open it could cause problems at certain rpms.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
