Back Fire on Start?
KarmaKid
84
Western MA
Whenever I start my 2002 GT, 70% of the time it seems to backfire. I wait 2 seconds and it starts with no problem. On the first attempt, it turns over begins to start followed by a pop or two pops out of the exhaust, then nothing. The only mods I have at the moment are BBK off road x-pipe with MIL eliminators and subframe connectors ( not that the connectors would have anything to do with it:-) ) I live in MA and it the temp started to change about a month and a 1/2 ago, which ironicly is when this issue started? It does not matter if the engine is cold or warm. I use 89 octane gas. I have had the vehicle since 09/09/06. This issue did not start until the weather changed. No other symptons that I can see. Weather related? un-burnt fuel from no cat's? Stuck valve?
P.S. Happy Holidays!
If it was only on cold starts Id say it would just be somewhat of a tune problem. My car did something like this but was after my SC and MPH Tune, and my half brother's car did this when his 02 was stock. With mine I had more fuel added on start up in the tune and on his he took it to Ford and fixed his, dont know how though.
The '02's have a hot starting issue. Some of them will "backfire" a bit at startup one time. After that, the issue disappears.
Related or not, my cam position sensor was out of whack. I had it replaced and have not had the issue since.
I know it's been discussed before. Hopefully, someone else will remember more, or it will come up in a search. Good luck!
Grrrrrrr....
Ok, so it was Sunday and the Ford dealership was closed, therefore I ended up at Autozone for the cam sensor. Wells manufactured I believe. Easy swap, just slightly remove the power steering pump, unscrew, remove then replace. Check engine light was gone upon first start then reared its ugly face about 2 days later. Still getting the backfire/pop upon initial turn of the key, but only intermittently. I have read in a couple other threads that peeps have replaced the alternator because their mechanics said the bad alternator was electricaly disturbing the cam sensor. Welllllll, yesterday I left my running lights/fog lights on which killed the battery. I tried popping the clutch and starting a few times with no luck. Today I tried jumoing the stang 4 times. Each time it would run for a minute or two then die. So I'm assuming it ran on the teeny tiny charge from the jump, then died because the alternators *****. So I'm going to pull both the alternator and the battery and have each one tested today. Fun Fun Fun.
