back fire through the intake question
I have had vacuum leaks & a low fuel pressure problem at separate times. both have caused crappy idle and back firing through the intake if I tried to rev the engine. My question is, why will a lean fuel condition cause a back fire through the intake? I understand that a rich condition will let unburned fuel ignite in the exhaust & cause an exhaust back fire. how does the intake back fire happen if your ignition & cam timing are correct? just a question out of curiosity.
i understand that timing being "out of wack" would cause an intake back fire. spark plug wires in the wrong order could also cause it but, if your timing and wires are correct, how does a lean AFR cause a back fire through the intake? I can only think of one explanation. Extremely Lean fuel mixtures burn slower because the fuel molecules are farther apart & if the the fuel hasnt all burned off by the time the intake valve opens again, the incoming charge will be ignited and blow back out the intake. This seems unlikely so, does anybody have a better explaination?
You haves stated the correct answer.:nice:
Wow! That was just a wild guess. I didnt think the combustion of a lean mix would burn all the way through the power stroke, continue to burn through the exhaust stroke, & still be burning when the intake stroke starts. Well thanks for confirming what was just a guess on my part.
would the octane of the fuel have an effect on that?
my guess is no because I only run 93 octane. from what i understand, octane is a fuels resitance to detonate due to heat. I would think 87 octane would ignite quicker even in a lean mix and there for have a little more time to burn up before the intake opened again. thats just a guess though.
My pcv set up when I had the vacuum leak was an explorer intake with a gutted pcv valve with a tube that ran to the passenger fender well. the tube on the filler neck had a tube on it that hung down beside the block connected to nothing. I know that is some unsafe red neck riggin so, my new set up has fittings i each vc with a tube that connects the two VC's and then from the passenger VC down to my homemade catch can that will have a clamp on filter real soon. I now have a knock off version of the vic jr intake modded for injectors that doesnt have a pcv port. that back fire issue was caused by low fuel pressure due to a bad ground wire to the pump & bat. That has been corrected too.
