back from the dyno & I got a question
just4bob50
504
Pa.
I had my car retuned after I rebuilt the top end because I put an E-cam in the motor and a smaller pulley on the blower. My car was tuned at a place called Pro-Tune in manhiem Pa. It made 368 rwhp a 5000 rpms and 421 rwtq at 4000 rpms. the AFR was between 12.1:1 and 10.5:1. The total timing was 19 deg. from 3500 on up. There was 10lbs of boost at 5000 rpms and about 12 at 5500 , but no matter what the tuner couldnt get it to make more power past 5000 rpms. Also the AFR was continually rich past 5000 rpms and the changes the tuner was making were having no effect. At 5500 rpms the AFR was 10.0:1. I have a feeling that my Crane HI-6s ign. is the weak link now. The motor is still has the stock heads on so the only changes were the cam and more boost. Does any one have any other ideas as to why power stops building at 5000.
the stock heads....and perhaps the Gt-40's stock lower? and i also dont think the E-cam will make much power after 5500. Did you rebuild the heads with better springs? there could be some valve float if you didn't.
fidstang said:
Do you have a FMU installed? Did he adjust the regulator? I'm just wondering because I'm getting ready to install a powerdyne on mine and wondered how the FMU is going to affect high RPM AFR.
I have the ford 90mm MAF and 42lb inj. and adj. reg. / all he had to do was adj the inj. through the lap top. Most tuners hate FMU's
86bluecobra said:
You say heads were rebuilt but did it get factory springs again or did you match em to the cam?
I beleive they are factory springs that were shimmed for a B-cam. The lift difference between the B & E cam is like .018. Either way I should get better heads when I can afford it.
