All,
I have a 95 convertible and I put the top down along with all the windows and now the drivers side window won't go back up.
The person I bought it from said the switch was replaced (it looks new as well) in the drivers door, and I just changed out the motor in the back (albiet a used motor).
I tested the motor a couple times before I reassembled the panel and whatnot, and it worked just fine. I tested it once I got it all back together and it worked just fine.
I went for a ride around the block and backed the car in the garage, turned it off. I waited for a bit and realized I should probably put the top back up, went out and the motor doesn't work again.
These are the same symptoms my old motor had. I am doubting that the motor is bad. I am wondering if I have a wire problem somewhere. Is there some way that I can test to make sure that there is power coming back to the motor and then also push power to the motor without the switch?
I really have a feeling that it is the wiring because it will work sometimes and not others. I don't hear anything at the motor end when it is not working.
This is really frustrating.
Thanks,
Keith
Thanks,
Keith
