backfire after plug change?
  • Thread starter Thread starter Jaswir
  • Start date Start date Dec 7, 2005
Jaswir
578
Orlando, FL
Dec 7, 2005
  • Dec 7, 2005
just changed my plugs... i went with NGK v power plugs.. now after the plug change with WOT or 3/4 of throttle pushed it backfires threw the exhaust! not loud just a bunch of lil ones... i check out plug wires everything is pluged in correct and is tight.. gaped them at 45 and before i had auto light 25s at 54.. think maybe its just a bad plug from the factory? also went to back of car and looked under it and my car has flows dumped so my eyes started to water because of unburnt fuel! so i think i might go back to auto 25s if i cant get to run right... any suggestions?
stang22
1,318
Washington, D.C.
Dec 7, 2005
  • Dec 7, 2005
You can't beat Autolite's!
Tim
ninety1gt
162
san antonio
Dec 7, 2005
  • Dec 7, 2005
no motorcraft plugs for teh win
04sleeper
2,674
14
89
Dallas, TX
Dec 7, 2005
  • Dec 7, 2005
Put back the Autolites and make sure you did not cross any wires.
Jaswir
578
Orlando, FL
Dec 7, 2005
  • Dec 7, 2005
i know for a fact i didnt cross the wires, i did one at a time and as soon as i changed one i put the wire back on it!
jimsstang91
101
  • Dec 7, 2005
that happened to me once and i think it was the wrong heat range.
04sleeper
2,674
14
89
Dallas, TX
Dec 7, 2005
  • Dec 7, 2005
OK. If you are sure you didn't cross any then I would try to put the old plugs back in to rule out the new plugs being the issue. If not you may have damaged the end of one of the wires.
Jaswir
578
Orlando, FL
Dec 7, 2005
  • Dec 7, 2005
hmmm think i found it... there was a vacumm leak off my charcoal canister one of the lines was dissconnected.. so if not gonna pop my old ones in and see what happens
Curse
791
El Paso, TX
Dec 7, 2005
  • Dec 7, 2005
Keep us posted. Good luck
HISSIN50
34
129
Dec 7, 2005
#10
  • Dec 7, 2005
  • #10
You can run a CBT to see if the puter can decipher what cylinder is missing (might be fun to do, for fun's sake).
I agree with Tim et al - go with Motorcraft or Autolite (I use the latter) copper plugs.
Good luck.
Jaswir
578
Orlando, FL
Dec 8, 2005
#11
  • Dec 8, 2005
  • #11
ok today i bought auto 25's what i always ran on my car and changed them now it runs WORSE! Now back fires loud as hell going above 3 to 4 thousand rpms! so i think it might be a plug wire maybe damaged one putting it back on? so i think im gonna change the plug wires tomorrow.. i don't know whats up with it
HISSIN50
34
129
Dec 8, 2005
#12
  • Dec 8, 2005
  • #12
If you have a timing light, you can toss it on each wire and hit the trigger. Look for an intermittant light pulsing.
Even just separating each wire from one another can help with cross firing.
Pulling codes and the CBT still could be helpful.
Good luck.
Jaswir
578
Orlando, FL
Dec 8, 2005
#13
  • Dec 8, 2005
  • #13
ok found the problem, it was the NGK plugs i put in... maybe they gave me the wrong ones? ok after i put in my auto lite 25s i put timing back to where it was.. because i played with it when i put the NGK plugs... what happen was i put spout connector in my pocket and forgot about it... so that was it i didnt put the spount back on after changing the timing... i guess i was in too much of a hurry... now im gonna change my balancer tomorrow!
Jaswir
578
Orlando, FL
Dec 8, 2005
#14
  • Dec 8, 2005
  • #14
thanks for the help guys!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 8, 2005
#15
  • Dec 8, 2005
  • #15
D'oh hate it when things like that happen
04sleeper
2,674
14
89
Dallas, TX
Dec 8, 2005
#16
  • Dec 8, 2005
  • #16
Glad to see you got it working.
HISSIN50
34
129
Dec 8, 2005
#17
  • Dec 8, 2005
  • #17
Yeah man, glad you figured it out without too much fuss. Locked timing at 10-14* sucks.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Dec 8, 2005
#18
  • Dec 8, 2005
  • #18
definetly had a buddy do that after he installed his nitrous kit. set the timing and forgot to put the plug back in. took it down the road, sprayed it and POP! blew a head gasket. we searched for quite some time to figure out what happened until i asked him if he ever put the spout back in after we set the timing since he was the one that took it out. well it was in his pocket. anyways, glad to hear its running better
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
Best plugs for carb'd roller
  • forango
  • Nov 21, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
HotFox
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
