backfire through the intake??
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Everynow and then my car will make a loud POP while throttling it.. it has to be when im playing with the throttle and it revving it up.. just wondering how bad is this and what can i do to get rid of it? again its everynow and then.. not often.. just when i give it a good bit of gas and she tac's 4k and come down and right about 2k i hit it again.. no fire or anything just a pop.. sounds exactly like a backfire coming up through a carb'd car just obviously coming through my intake
Backfiring is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
i have a code scanner here.. i will run the codes then. Also i run 18* degrees of timing, autolite 26's (hotter) plug.. my EGR is plugged in.. just there are no vaccume lines etc thats hooked up..
