jimsstang91 New Member Dec 4, 2005 101 0 0 May 18, 2006 #1 May 18, 2006 #1 when the car is cold i get a popping backfire though the intake or throttle body. when its warmed up its fine. what could this be???
gcwh02 New Member Jun 20, 2005 515 0 0 pottstown, PA May 18, 2006 #3 May 18, 2006 #3 could be from running to rich, whats your setup and fp at?
Roland69 Sergeant Tangnet Sep 17, 2005 2,867 3 58 Port Elgin, Ontario May 18, 2006 #4 May 18, 2006 #4 what year is your car
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 19, 2006 #5 May 19, 2006 #5 This backfire occurs when idling, while RPM's are gently increasing, rapidly increasing.............? What codes are you seeing (Pull them even if the CEL has not been illuminated)? What is your timing set at? Offer as much info as you can - there are myriad possibilities for such an issue. Good luck.
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle May 19, 2006 #6 May 19, 2006 #6 jimsstang91 said: when the car is cold i get a popping backfire though the intake or throttle body. when its warmed up its fine. what could this be??? Click to expand... What are you calling warmed up? Full coolant temp, or just coming out of open loop/startup? How long does this usually take? jason
