  • SN95 4.6L Mustang Tech
Backfire???
  • Thread starter Thread starter Bundmar
  • Start date Start date Jun 12, 2007
Bundmar
377
Ontario, Canada
Jun 12, 2007
  • Jun 12, 2007
Ive noticed that my car has started to backfire when I step on it hard and shift at high RPM's, mostly happens when I shift into 4th and Step on it...anyone know what coudl be causing this? and is it safe?
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 13, 2007
  • Jun 13, 2007
backfire or misfire?
no check engine light?
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Jun 13, 2007
  • Jun 13, 2007
are you using cheap gas?
9
97speedster
134
stanwood,wa
Jun 13, 2007
  • Jun 13, 2007
Check for water in the heads where the plugs go. Very common problem. How long since you changed your plugs and wires?
Bundmar
377
Ontario, Canada
Jun 13, 2007
  • Jun 13, 2007
use 94 octane, plugs and wires are good, backfire no check engine light???
smokin00GT
80
United States
Jun 13, 2007
  • Jun 13, 2007
Backfire can be caused by not enough back pressure in your exhaust. It also can be caused by running rich. Popping sounds are signs of being lean. What exhaust do you have?
9
97speedster
134
stanwood,wa
Jun 13, 2007
  • Jun 13, 2007
Have you tried cleaning your MAF sensor?
Bundmar
377
Ontario, Canada
Jun 13, 2007
  • Jun 13, 2007
prochamber and flowmaster mufflers and I just got it tuned and the A/F is at 11.7 so its not lean...
blkhorse
345
Jun 13, 2007
  • Jun 13, 2007
backfire through intake-usually lean,backfire out exhaust(under load)secondary ignition(coil,plugs,wires)
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
F
Car dies on bumps and when braking
  • Feckl
  • Jul 14, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
