Backfiring through intake??
Wicked_306
45
Ok, I drove my car to work and back with no problems. It was just fine when i parked it and didn't drive it for a couple of days. Now at idle it backfires out of the intake about every 10-20 seconds. I didnt do anyting to it from the time I drove it before, It feels like it is running off of 6 cylinders, it has no power and even sounds different. I have no idea what it could be because I didnt do anything to it except install autometer gauges but that has nothing to do with it. Its a 306 with about 2000 miles, tfs stage one, kieth black dome tops, bolt on's ect...I havnt had any problems till now. Any help is appreciated. Thanks
PS The timing is set on 20 degrees where I have always ran this motor with no probs and I dont have a fuel pressure gauge, so I dont know what it is set at but I have a stock fuel pressure regulator on it.
A trick to find out what cylinder is giving you problems:
With the motor off remove one of the plug wires off of the distributor. Start the motor. If it runs worse, that cylinder is functioning fine. Turn off the motor and move on to the next plug wire. Reconnect the previous wire before removing the next one to avoid confusion. Make your way around the entire distributor
*Remember to remove and install the plug wires with the motor off. You don't need to be getting an unnecesary shock.
You can also dump the codes pretty easy out of the computer (you only need a 2" piece of wire.) This will also do a cylinder balance test which is the easier method to the trick I posted above.
These methods will only tell you which cylinders are at fault.
Backfiring: When the intake valve on a cylinder is open too long and the combustion mixture is ignited. The ignited mixture then travels up into the intake looking for more oxygen. One or two of your cylinders have intake valves open too long. Or opening at the wrong time.
Engine backfires:
1.) Excessively lean mixture. Look for vacuum leaks, low fuel pressure, dirty injectors or bad injector electrical power, EGR stuck open.
2.) Spark plug wires crossed or cross-firing.
3.) Sticking intake valve, bad valve spring, poorly adjusted valves.
4.) dirty or failed MAF sensor - look for code 66 when you dump the codes.
Use a vacuum gauge to look for sticking valves. The reading will be low (8"-14" @ 1200 RPM) and the needle will sweep every time the cylinder fires.
Use a fuel pressure gauge to tap the fuel pressure test point just behind the alternator. Measure the pressure with the engine idling, vacuum line off the fuel pressure regulator. You should see 38-40 PSI.
Do a cylinder balance test to isolate bad cylinders.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 for everything OK, or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles...-iv_codes.html
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/deta...ption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
20 deg BTDC spout out? Seems high. This might indicate a timing chain problem or messed up damper
Original timing chain? Maybe stretched / hopped a link.
Back your timing back to stock see what happens. Check plugs. What do you see?
Yes, I have ran it tuned like that since it was built. It is a stock timin chain. I have messed with the timing and it doesnt change the way it feels, feels like its got half the power it used to. All of the plugs looked like the cylinders were running lean except for # 7 and 8 cylinders were running rich? What could that mean? It just feels like something is totaly not tuned right on the car. Something happened from the last time I drove it because it was just fine then I parked it for a couple of days and put gauges in it and feels like it has half the power and feels like sh**. It runs really rough when trying to accelerate and will barely accelerate. If the distribiter was bad would it show up on the check engine light? Thanks
