Backing Break Cable Snaped
TSWG00
202
Snohomish, WA
Parking Break Cable Snaped
So as you can see by the title about 2 weeks ago. When I was parking, I pulled on my E-break and Snap. The cable broke. So now I have to figure out how to remove the console so I can remove the cable and replace it. I can't find my service manual. but it seems pretty simple. Is there a trick to getting the console out? From all I can see there are 2 bolts by the shifter. But then again I could be way off. Any pointers? Thanks
Removing the console is easy.....
1. Remove shift knob.
2. Remove shifter bezel.
3. Remove the 2 screws you referred to.
4. Two tiny rubber grommets under console lid. Pry them out.
5. Remove 2 screws under the grommets.
6. Remove the entire insert that you just loosened. (lift front first)
7. Remove 2 screws in bottom of console (may need extension).
8. Lift entire console out.
Thanks if I need more help I'll post again
i just removed mine... and that musta been straight outta the manual. Cuz he said it all, you shouldn't need anything else.
I had to pull my ebrake as far up as possible, i repeat as far up as possible! and work the slot for the ebrake around the handle, thats just a tip tho.
