bad battery tray, bad
  • Thread starter Thread starter blinkboy5788
  • Start date Start date Jul 26, 2004
blinkboy5788
Western Washington
Jul 26, 2004
  • Jul 26, 2004
no surprise my battery tray is rusted. that then leaked to the inner fender apron thingie that its connected to so thats rusted too. i have all the replacement parts now but i just have to get them in. first thing is how do i get the welds off that are holding the old inner apron on? than how do i prep the new one because they sent it to me as bare metal? and how do i drill the holes needed to mount it again and do i have to get it welded again like the old one? lots of general questions about fixing this stuff. i wanted to get this done now because my car had just recently been involved in a hit and run so i have no fender so easy access to all this crap. help me out. see ya!
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 26, 2004
  • Jul 26, 2004
Aplasma cutter would be the best way but a cutoof wheel on a grinder will work. Check your radiator support for rust as this is common in this situation. A professional job might be worth the money here.
R
rmrfstar
31
Chico, CA
Jul 26, 2004
  • Jul 26, 2004
I had mine done by a professional a few years ago and I was not totally happy with how it turned out, the welds are obvious. They cut out the rusted parts and welded the new stuff in. Now I would do it myself, cutting wheel and a mig.
RajunCajun
180
  • Jul 26, 2004
I replaced mine for the same reason, purchased my repo one from DallasMustang, took some dolly and hammer work to make it fit right but other than that a perfect fit. I chose to drill out the spot welds all the way through the shock tower side of the panel through the edge and used spot weld drill bit for all the other spot welds all the way around the panel, then cleaned it all up smooth and fitted the new panel and plug welded the panel in from the outerfenderwell area of shock tower (those previous holes i drilled) then grinded them smooth and plug welded the others , completely finished you cant tell it was ever replaced, even though it will never see another battery it looks original.
slapper
447
  • Jul 27, 2004
Where are you at in Western WA.?
I can take a look at it for you if you want.
Seattle area.
blinkboy5788
Western Washington
Jul 27, 2004
  • Jul 27, 2004
marysville, but since the right fender is off right now cause of the hit and run im gonna get the guy whos fixing that to do the battery tray at the same time. hopefully he will do it good. thanx anyways guys.
slapper
447
  • Aug 9, 2004
I'm right up the road from you.
Aqua 1968 fastback.
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
