just wondering what are the signs of a bad dizzy or one that might be on it's last leg if there is such a term? My car after I set the idle a few wks ago drove like it was a new car when I drove after setting idle. Now I have noticed cranking the car sounds like it takes just a hair , maybe split second longer and seems like the crank itsn't as strong, isn't as powerful sounding though it still cranks and sounds ok just not as strong as I know it used to. Also have a low rpm jerk/buck, slight miss until I take off. Everything is up to date as far as plugs wires, fuel filter, cleaned MAF and cleaned IAC about 3-5 months ago, cleaned tb after taking off upper intake. Googling said some things about how with the cams especially the alphabet cams and 94-95 cars you will just have that buck and jerk but since 02 I noticed my car didnt always do it. Seemed like after setting idle and tps those things went away. I notice the car drives nice and strong now, shifts thru rpms fast but just has that low rpm buck slight miss. I used the idle set procedure using the idle bypass screw and a procedure I actually saw here on this forum which is pretty much the same as the professional products tb that I have calls for
