  • 1994 - 1995 Specific Tech
bad engine vibration, please help quick
  • Thread starter Thread starter viridionplague
  • Start date Start date Jan 18, 2008
V
viridionplague
98
  • Jan 18, 2008
so i started my car today after being gone for 4 days, its been cold out,
it started fine but it vibrates realy badly, it didnt do this before today at all and i need to know what it is.
the vibrations get a little worse at around 1300 rpms as well
also this is not moving but in park, with a 5 speed
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
A couple things come to mind. Could be the balancer, could be a frozen injector that will thaw with engine heat, and the idle will stabilize. You could run a cylinder balance test to rule out any particular cylinder if the balancer checks out.
V
viridionplague
98
  • Jan 18, 2008
well i had the engine up to temp and it was still very shaky
so a balanger maybe?
how much is one of those going to run
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jan 18, 2008
  • Jan 18, 2008
Check the balancer on the side facing the rear of the car. If there is a rubber part that is coming out of it, then you need a new one.
Autozone has a replacement for about $60, but you could get a Professional Products balancer for about $80 and they're not supposed to fail at all. I'd go that route and will when mine gives up.
V
viridionplague
98
  • Jan 18, 2008
well i just went out and checked the balancer, although i cannot SEE it very well,
i deceded to stick my fingers behind it and sure enough it feels like there is a rubber piece sticking out of it, by probably half an inch or so
good thing my GF wanted to go to the store today, cause i wasnt going to go anywhere and i drive for pizza hut tonight
thanks for the quick help guys
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
