  • SN95 4.6L Mustang Tech
bad fuel pump or IAC
  • Thread starter Thread starter mikenjillstangs
  • Start date Start date Sep 4, 2006
M
mikenjillstangs
  • Sep 4, 2006
99' g.t ....so heres what happens I press clutch, turn the key it turns on momentarily revs up as usual then drops within two seconds of turning key and shuts off . I can however, keep the car running so long as i press the gas pedal. Any opinions or advice would be greatly appreciated
M
mikenjillstangs
  • Sep 4, 2006
also the check engine light is on thanks again for help
P
Pennywise2
Banned
May 16, 2006
1,379
  • Sep 4, 2006
Welcome to Stangnet.
The same thing happened to me when my IAC went bad.
The IAC went bad after 60K miles.My check engine light
came on too.I had to install a replacement Motorcraft IAC valve and clear the code all was fine after that.
I highly subjest you go with a Motorcraft replacement IAC valve and not a cheap off brand.A IAC is one part I
would never go cheap on.Good luck I hope you fined the fix.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Sep 4, 2006
  • Sep 4, 2006
Its IAC. But if you cab, get the code pulled
04gtdrop
532
Sac, CA
Sep 5, 2006
  • Sep 5, 2006
my guess is a bad IAC.
madmatt
Ellis Juan sympathizer
465
Lexington, SC
Sep 5, 2006
  • Sep 5, 2006
Id put money on the IAC. Clean it out with some brake cleaner/carb cleaner, if that fixes it, you know its your problem. Then get a new one soon.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 5, 2006
  • Sep 5, 2006
Pull the code, most likely IAC, does the car have the original fuel filter?
M
mikenjillstangs
  • Sep 6, 2006
hey got it all fixed thanks everyone it was the IAC getting a new one got carb cleaner in the old one for now going to get code pulled as well thanks a lot later
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
