bad gas mileage
gcwh02
515
pottstown, PA
For some reason my gas mileage went down teh drain. I went about 100 miles and it costed me $24 bucks to fill the tank. I am running a high flow cat X pipe, timing is at 14, and a very tiny exhaust leak at the header. It still should be getting better gas mileage than that. Anyone have anything?
That info doesnt mean much. YOu need to drive a larger distance to infer an issue. For instance if at one fill up, the pump clicked off too early, then you drove till yesterday and filled up at a station with a clicker on the pump that worked normal, it would throw off the milage. Price of gas would also help us guess how many gallons you needed.
Staying out of the gas pedal, avoiding extended idling and pullnig codes are places to start.
Good luck.
Cougar5.O said:
No, you see it cost more to fill your tank because gasoline it 20% more expensive than the last time you bought it :D
I get 15.5 MPG - you better get better than that.
Haha gas is going up but I get worse than 15 mpg, and thats how i know something is wrong. This isnt just out of one 100 mile gas fill up. This has just been guzzling gas up latley. No check engine light either. Sucks...
Poor gas milage
Where did you buy it from? Whats the ethnol content? % water, octane % all these factor into the equation, as well as the speed, city or highway.
I know if I buy gas a from station X & Y instead of Esso or Shell in my area I end up with less then stellar milage. The cheaper no-name brands run a higher alcohol content.
My wifes LX only got about 15 MPG when we bought it.after changing the full exhaust system and O2 sensors, it went up to over 20 MPG.
I have heard people say that you should not reuse O2 sensors when changing exhaust, for some reason it affects them. I have no scientific proof of that.
When O2 sensors go bad, it does not affect performance but does affect fuel milage. May or may not be your problem.
Cliff :)
There can be code type problems without the check engine light being on.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Cliff :)
Actually that could be it, i kept the same O2's when swapping my midpipe. I'll get some new ones im sure they are due for a change.
Prior to my H/C/I swap 20mpg was my low (still tuning H/C/I). I started getting bad mileage so I changed the O2's and was planning on changing my FPR. I bought a gauge at the same time and my FP was 3psi to high. I change the FPR and set FP to 38psi and picked up 50 miles to a tank which put me around mid 20s MPG. I was getting 275-280 before the fuel light came on. Anybody getting 15mpg has some tuning issues or they are 100% on the throtte and 100% off the throttle every 5 seconds with 4.30 gears.
