  • SN95 4.6L Mustang Tech
Bad idle and low speed
  • Thread starter Thread starter Duramaxmike23
  • Start date Start date Sep 14, 2011
D
Duramaxmike23
D/FW
Sep 14, 2011
  • Sep 14, 2011
Hey guys, new to the forum. Got a problem for ya.
I've got a 98 Cobra. It runs fine while it's cold, but by the time it fully warms up, it starts idleing low and somewhat erratic. Even to the extent of it stalling if I let it idle too long. It sounds like it's just loading up. And then there's the driveability issue. When it's acting funky, it'll be really sluggish and sputtery. But if I press the gas just enough, it makes a very faint sort of a muffled pop from the intake and runs fine. Like the problem only exists at idle and part-throttle. Seems like it's got an excessive amount of fumes at idle too. I read a bunch of different threads, and found one that mentioned changing the thermostat. It didn't suit my problem to the T though. The car has mil eliminators on it, but threw a couple codes for the rear O2 sensors anyway, the other day. I cleared the codes, and they haven't tripped again. The car is just aggravating to drive. I've put 2 different mass-air meters on it, put in new plugs, put in different O2 sensors, unplugged the computer for awhile, and unplugged various sensors to see if they made a difference good or bad.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 14, 2011
  • Sep 14, 2011
A low idle is usually either a vacuum leak or one or more cylinders are not pulling their weight (power balance).
When was the last time the PCV value was changed? Start there. Then go back and really LOOK for a vacuum leak.
Check out:
Is your mustang stumbling, dieing at idle or idling rough? - Page 14 - Ford Mustang Forums
D
Duramaxmike23
D/FW
Sep 15, 2011
  • Sep 15, 2011
Nope, no vacuum leaks. I've checked and re-checked. I'm at a loss with it, but I'm about to go tinker with it again. About 10-12 years ago, I had a fox body that did the same thing, more or less. I sure wish I could remember what I traced the problem to!
nyuk98gt
1,427
Chesterfield, MO
Sep 15, 2011
  • Sep 15, 2011
Duramaxmike23:
If no vacuum leaks then let's consider the IAC valve. When it fouls, it can cause idle issues. Although it may just be a temporary fix, give the valve a cleaning (carb cleaner, tap, tap, tap to knock the crud out of it, repeat until the amount of crud is down to almost nothing). It things improve, replace with an OEM valve.
HTH,
Chris
D
Duramaxmike23
D/FW
Sep 15, 2011
  • Sep 15, 2011
Today, I tried changing the IAC and coils, along with putting the previous plugs back in. Ok, so here's what I've found. There's that tubular water pipe that goes into the heads. It's got a sensor on both sides. I think the one on the drivers side is for the temp guage. The one on the passenger side is where my problem is, I think. While the car was acting crappy, I unplugged it. The idle quality immediately cleaned up, but went up to 1200rpm. So I figured that sensor was bad. I've got another car that I can swap parts from, to keep me from just throwing money at it. Anyway, I put the sensor in from the other car, and it acted the same way. So I unplugged the sensor, and plugged in original one that I was holding in my hand. The car idled perfectly. So I took it for a spin. The car drove great for a few miles, then started acting goofy again, but not as bad as originally. So when I got back to the house, I popped the hood to check it. The sensor was hot because it had been sitting against the water tube. It seems as though the car ran fine while the sensor was cold, but then as the sensor heated up, it started showing the same signs as the sensor in the water pipe. It just amazes me how bad this is stumping me! lol
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 15, 2011
  • Sep 15, 2011
Can you post pictures? I want to make sure that we are on the same game page.
When the cooling system was last drained, how was it re-filled? Did you follow the DOHC re-fill procedures? If not, there is AIR trapped inside the motor/crossover. The DOHC and V6 are very difficult to get all of the air out.
D
Duramaxmike23
D/FW
Sep 18, 2011
  • Sep 18, 2011
I dunno what the "proper" way to fill the system is, but I filled the tank up to the line and pulled the plug in the cross-over tube and filled until it overflowed out of it. After a dozen or so heat cycles after filling the system, the water level remains constant in the radiator. I probably should go ahead and change the thermostat also, to take it out of the equation. Would it be a good idea to take that thermostat bulb off, and go back to a traditional single hose on the bottom with an inline thermostat? The factory hose routing doesn't look too efficient.
D
Duramaxmike23
D/FW
Sep 18, 2011
  • Sep 18, 2011
When I pulled the sensor out, water came pouring out. So I'm sure there's water in the top of the system, but maybe not enough.
D
Duramaxmike23
D/FW
Sep 18, 2011
  • Sep 18, 2011
So, I did a search on the filling procedure. When I put a new thermostat in it, I'll follow those guidelines. Still not sure though, the heater blows hot and the car warms up like normal. I'm not opposed to trying any suggestions though. Thanks guys.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 18, 2011
#10
  • Sep 18, 2011
  • #10
If you are serious about solving this, some serious tests will be needed. Please perfrom all tests and post the results.
Does "loading up" mean that it is running rich? CONFIRM that the intake fuel regulator vaccum reference line is connected and leak free. Do you have any way to measure the fuel pressure at the rail?
Measure the voltage at the trunk IFS switch when cold and again when the idle begins to get poor.
Have there been any mods or repairs to the fuel system? New fuel pump especially an upgraded or non-stock fuel pump?
How old are the front O2 sensors? And what brand? Does the car have long tube headers?
How does the car run otherwise? Gas mileage?
Did you REPLACE the PVC valve. Did you insptect the vaccum hoses, PCV donut, oil dip stick, oil fill cap for vacuum leaks?
Did you inspect the throttle return spring and is it closing the throttle tight? Does the throttle linkage work freely?
Has there been any mods to the IMRC's?
Are there any exhaust leaks?
It would be handy to know what the PCM thinks is the engine's temperature and air temperature. Would also help to know what the LTFT's are at idle and under load. Do you have an ODB2 scanner capable of monitoring operational data?
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
