bad lifters?
  • Thread starter Thread starter dilligaf
  • Start date Start date Jul 9, 2005
dilligaf
25
Midwest city, ok.
Jul 9, 2005
  • Jul 9, 2005
ok, so i've got my intakes off. how can i tell if my lifters are bad? my car has been making a ticking sound for about 2 months, and then all of a sudden my car sounds like a rocker came off. so i tear it all down, hoping that what ever is making the noise will make itself obvious. but it didn't. the rocker did not apper to be loose although i didn't have a socket to turn the crank over. but one push rod did have slop in between the rocker and lifter.
it's a 93 cobra motor, e-cam, 1.7 crane rockers if that makes a difference.
Sicarius428
2,085
Jul 9, 2005
  • Jul 9, 2005
Push down on the rocker side where the pushrod is. If you feel that it is really squishy or bottom out... that is the bad pushrod.
Kevin
vikingpower
656
CWU Ellensburg, WA
Jul 9, 2005
  • Jul 9, 2005
did you check your header gaskets to make sure you didnt have a small leak that turned into a blown gasket, happened to me so I went with copper header gaskets
dilligaf
25
Midwest city, ok.
Jul 9, 2005
  • Jul 9, 2005
no' i haven't checked the header gasket yet. but it doesn't sound like an exhaust leak though. but i will look into it though. i'm just praying that it's nothing on the bottom end of the motor.
blue87lx
175
  • Jul 9, 2005
header leak wont sound like an exhuast leak sounds liek a loud tapping
dilligaf
25
Midwest city, ok.
Jul 10, 2005
  • Jul 10, 2005
well, im going to go ahead and buy the lifers and put them on and i will buy some new header gaskets while i'm at it and see what happens.
dilligaf
25
Midwest city, ok.
Jul 10, 2005
  • Jul 10, 2005
any other opinions before i put it back together?
Black1987Stang
1,422
Jersey Shore
Jul 10, 2005
  • Jul 10, 2005
Make sure you retorque all ur lower intake bolts. I have to go over them like 4 times until they are at the full torque spec, i guess also depends on how much silicone I used too.
dilligaf
25
Midwest city, ok.
Jul 11, 2005
  • Jul 11, 2005
well, i noticed that one of the exhaust valves was sitting quite a bit lower than the rest so i bit the bullitt and took the head off. guess what i found? yup, a bent valve. so i guess i'm going to have the heads worked and see what happens. thanks for all the information. i'll keep you posted on the progress.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
Y
Engine Oily cylinder- bad lifter relationship
  • Yoyoda
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 16, 2024
Yoyoda
Y
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
