  • SN95 4.6L Mustang Tech
Bad Squeak
  • Thread starter Thread starter Mustang all way
  • Start date Start date Jul 7, 2010
M
Mustang all way
  • Jul 7, 2010
I have a bad squeak in my left passenger front side. I replaced the struts thinking that was it. If anyone has any idea of what this could be let me know. I'm thinking maybe its the a arm or a ball joint but not sure. If anyone has any information please let me know Thanks
BetterBaGT
49
Phoenix, AZ (unfortunately)
Jul 7, 2010
  • Jul 7, 2010
Can you give some more information? When does it occur? How often? What type of noise is it specifically? Any other specifics.
trinity_gt
3,125
81
99
Canada
Jul 7, 2010
  • Jul 7, 2010
Better's right: Need more info.
But here's a stab: Sway bar bushings. Get some silicone spray into the bushings where the bar passes through and on the end-links. If this helps it may be time for new bushings.
syc_stang
jacksonville , fl
Jul 7, 2010
  • Jul 7, 2010
does it get louder as you turn either direction? i had the same issue. it got louder as i turned to the left . the problem for me was my front left hub and bearing assembly.
M
Mustang all way
  • Jul 7, 2010
It does it worse as i hit bumps. Any lil bump makes it do this and i sprayed som PB on arms to see if that helped and it didnt.... I mean i had struts replaced few weeks ago and it was still there and im totally lost on what it could be...
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jul 9, 2010
  • Jul 9, 2010
Try greasing your outer-tie rods, they are re-greasable. Plus 1 on the front sway bar, I would use white lithium grease, from my experience when your ball joints start to go, they tick.
Try spraying the WLG on your A arm bushings. There are kits you can buy off Ebay that replace all of your bushings, including the rack pinion casing bushings, when those go bad, your wheels will start to rub on your frame when you turn the wheel completely left or right.
Also, your rotors could be glazed, from having some kind of grease on your rotors. Check your brake pads. Are they shiny and completely flat. Your rotors would be shiny and glazed looking as well, when you hit a bump, that could the rotor hitting the brake pads.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 10, 2010
  • Jul 10, 2010
What he said. I'm 90% sure this is a tie rod end needing some white lithium grease. This is sounds exactly what happens when that's the case.
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
