- Mar 31, 2005
- 11
- 0
- 0
A couple of weeks ago, I took my weekender 90 LX 5.0 out for a spin. Started right up made a few miscellaneous stops then went home. Later that day when I started the car move it to the driveway, the engine started right up, but a high pitched squeal was evident. I turned the ignition off and the engine stopped but the squeal did not. Had to disconnect the battery to get it to stop. I had to run it like that to pull it into the driveway then I again had to disconnect the battery to get the sound to stop. I had just replaced the starter relay a few weeks before and the ignition seemed to be acting OK, so I got a new starter. Well, I can't put the damned thing in. To be more precise, I can't get the old one off. The lower bolt I can reach just fine, but I can't even get my fingers on the upper one, let alone get a wrench on it. To those who have done it, how the heck did you get to the upper bolt. It's blocked from above by various engine and exhaust components and I can't see it from the side with the wheel off. Am I missing something here? Everybody says it's a half hour job. If you've done it, how the heck did you do it?
Also, to guard against a bad relay, I bought another OEM starter relay. Put this on first and fully charged the battery last night. I also replaced the battery ground with an OEM unit as the terminal was in pretty sorry shape. Now, with this new starter relay, the original starter (remember I can't get the new one on) just spins without turning over the engine. The engine will not turn over. All other electrical stuff is working as usual. I figure I may have burned out the last starter relay with maybe an undercharged battery or maybe it was just a bad relay. Any thoughts?
