Bad Stutter After Wot
Dremxx
Ohio
Recently replaced my stock intake manifold with a new doorman one and also replaced the up flow o2 sensors in my 2002 mustang gt with 141k miles (the car is tuned and the down flows are disabled) . About 2 weeks after i replaced the two i started to notice a bad stutter after wot (appears at around 4k - 4.5k rpms). The car begins to stutter, the exhaust seems to cut in and out with the stutter, and there is a strong oil smell after. The stutter lasts for about 10 - 30 seconds and then the car seems to be fine after. This has me stumbled and i cant seem to figure out the issue myself. Bad valve seals? Thanks for any suggestions.
There are two areas that I would rule out at the beginning.
  • Voltage drop caused by alternator brush bounce
  • weak ignition cutting out at times of high cylinder loading.
  • all of the above.
  • something else
It's very possible that alternator drop out is also CAUSING an ignition problem. Don't discount the possibility of this symptom being related to poor charging voltage.
Howto perform charging system voltage drop test
