Bad Tuning problem please help
i have a doozey for all of u and i am still sittin here befuddled at best. here's my scenario i have an 88 gt mustang trick flow twisted wedge heads, 1.6 rockers, f cam, 60lb injectors with a 60 maf to go with it, s trim supercharger from vortech with an anderson power pipe, also trick flow air intake, along with 75 throttle body and a bbk x pipe to boot. major tune problems to begin with the tune won't let me play with the fuel to air ratio and it won't let me by pass the timing of the car. i found top dead center and the car still won't run right it idles fine when cold as soon as temp hit's 100 degrees car stalls out and won't start any suggestions fixing this headache i heard it could be in the wiring harness but not sure?:notnice:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
but i changed the car over from speed density to mass air so i changed out the computer and i believe that connection is not even used
It is still used. All 5.0 Mustangs made between 86 and 95 used the same diagnostic connector and the same method to dump the codes. Even if you used a mass air conversion kit, the diagnostic connector still works the same.
What codes did you get?
What ecu do you have?
How are you trying to 'play with the afr' and 'bypass the timing'???
Why isn't your tuner working these issues for you??????????????????????????????
A friend of mine just had his tuned . When they tried it wouldnt take his computer was bad . They used a sct chip on his to. Changed the computer and worked great!
tried swapping the computers it was not the problem. checked all grounds too and that isn't the problem either kind of stuck at this point and suggestions would help
Surely you have a paper clip handy to dump the codes. This is the first step in troubleshooting 5.0 Mustangs.
This may come off as being rude, but that isn't the intention...
Why are you asking for help, if you aren't going to listen to the answers?
Pull the codes, and let us know what they are. JRichker is pretty good at getting these things straightened out.
You have not let us know what ecu you have.
What functions is the tuner trying to use to change Timing and AFR?
It's doubtful that this is a 'tuning' issue.
Most likely there is a failure in your system somewhere.
Take the time to properly diagnose the problem. Otherwise the best you can do is start buying new parts, which gets expensive.
Lastly,
Why isn't your tuner working this stuff out?
In my mind, this is part of what you pay him for... the expertise needed to sort out these issues.
trying everything
well vristang that's just it he has been trying everything and we come down to it being something in the electrial system that isn't allowing us to tune the car at all so it when we do dump the codes i will let you know what i get for a reading and then maybe i can figure where to go from there
Again, not trying to be rude....
But telling us you have "tried everything" doesn't help us to help you.
What have you tried? Results?
Hopefully the tuner has already checked the codes... he should know to start with that.
here's what weve done so far
dump the codes nothing there. like i said before he thought maybe the timing was off tried that no dice. then we tried changing the computer itself that was not the problem same result with new computer. then we went with the grounding block is grounded to the fire wall and the injectors are grounded to the block nothing there. then we check the throttle position sensor and the mass air meter both in working order throttle position sensor is at .93 so that's not the problem. next up we tried the vacuum lines to make sure there's nothing going on. i have a brand new egr valve on the car so that's fine too. is there anything else i could try before changing out the harness?
